Ethernet Products
4919 Discussions
Unable to update firmware for x710 update not available
nkoconno
Hello, I'm running ESX8
Here's my current firmware and drivers;
esxcli network nic get -n vmnic0
Advertised Auto Negotiation: true
Advertised Link Modes: Auto, 100BaseT/Full, 1000BaseT/Full, 10000BaseT/Full
Backing DPUId: N/A
Cable Type: Twisted Pair
Current Message Level: 1
Driver Info:
Bus Info: 0000:a1:00:0
Driver: i40en
Firmware Version: 8.30 0x8000a9b7 1.2926.0
Version: 1.11.3.10
Link Detected: true
Link Status: Up
PHYAddress: 0
Pause Autonegotiate: true
Pause RX: false
Pause TX: false
Supported Ports: TP
Supports Auto Negotiation: true
Supports Pause: true
Supports Wakeon: true
Transceiver: internal
Virtual Address: 00:50:56:58:bb:5d
Wakeon: MagicPacket(tm)
esxcli network nic get -n vmnic5
Advertised Link Modes: Auto, 100BaseT/Full, 1000BaseT/Full, 2500BaseT/Full, 5000BaseT/Full, 10000BaseT/Full
Backing DPUId: N/A
Driver Info:
Bus Info: 0000:44:00:1
Driver: i40en
Firmware Version: 8.50 0x8000be1e 1.3082.0
Version: 1.11.3.10
Link Detected: true
Link Status: Up
PHYAddress: 0
Pause RX: false
Pause TX: false
Supported Ports: TP
Virtual Address: 00:50:56:5d:ec:26
Attempting to use the 9.40 firmware from here: https://www.intel.com/content/www/us/en/download/18190/non-volatile-memory-nvm-update-utility-for-intel-ethernet-network-adapter-700-series.html
I copied the tar file up to a vmfs datastore and extracted;
700Series_NVMUpdatePackage_v9_40_ESX.tar
I ran the following;
[root@esx02:/vmfs/volumes/64680e35-8b8e8790-91a8-3ceceffcf592/intel/700Series/ESXi_x64] ./nvmupdaten64e
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.40.5.5
Copyright(C) 2013 - 2023 Intel Corporation.
WARNING: To avoid damage to your device, do not stop the update or reboot or power off the system during this update.
Inventory in progress. Please wait [|.........]
Num Description Ver.(hex) DevId S:B Status
01) Intel(R) Ethernet Controller X710 8.80(8.50) 15FF 00:068 Update not
for 10GBASE-T available
02) Intel(R) Ethernet Controller 8.48(8.30) 1589 00:161 Update not
X710/X557-AT 10GBASE-T available
Tool execution completed with the following status: Device not found.
Press any key to exit.
The same process works fine on esx7, but on gigabyte hardware vs supermicro
How can I upgrade the firmware on my cards while running esx8?
Fikri_Intel
Hi nkoconno,
Thank you for reaching Intel Community.
Based on the issue, we can see there are mismatch with Device Driver and Firmware Version in ESXI 8.0 U2.
Your current version:
 Driver: i40en
Version: 1.11.3.10
Driver: i40en
Version: 1.11.3.10
Kindly refer to the below link from VMware Compatibility Guide for upgrade the firmware while running ESXi 8.0 U2 :
https://www.vmware.com/resources/compatibility/detail.php?deviceCategory=io&productid=37994
Fikri_Intel
nkoconno
Thanks, but that is the link to acquire the certified drivers from vmware for the intel nic.  My issue is with firmware upgrades.
Here's the drivers/firmware on my esx7 host - fw 8.10 / driver 1.11.1.31
[root@esxi2:~] esxcli network nic get -n vmnic2
   Driver Info:
         Bus Info: 0000:41:00:0
         Driver: i40en
         Firmware Version: 8.10 0x800093ea 1.2829.0
         Version: 1.11.1.31
   Link Detected: true
   Link Status: Up
   PHYAddress: 0
   Pause RX: false
   Pause TX: false
   Supported Ports: TP
   Supports Wakeon: false
   Transceiver:
   Virtual Address: 00:50:56:59:4c:63
   Wakeon: None
 Firmware update successful 8.10 to 9.4
[root@esxi2:/vmfs/volumes/661148bc-c11d7ae0-14ce-d85ed369312c/intel/700Series/ESXi_x64] ./nvmupdaten64e
Inventory in progress. Please wait [***|......]
01) Intel(R) Ethernet Network Adapter   8.16(8.10)   15FF 00:065 Update
    X710-T2L                                                     available
Options: Adapter Index List (comma-separated), [A]ll, e[X]it
Enter selection: a
Would you like to back up the NVM images? [Y]es/[N]o: y
Update in progress. This operation may take several minutes.
01) Intel(R) Ethernet Network Adapter   9.64(9.40)   15FF 00:065 Update
    X710-T2L                                                     successful
A reboot is required to complete the update process.
Tool execution completed with the following status: All operations completed successfully.
  After reboot driver 1.11.1.31 / firmware 9.40
   Driver Info:
         Driver: i40en
         Firmware Version: 9.40 0x8000ecc3 1.3429.0
         Version: 1.11.1.31
   Link Detected: true
   Link Status: Up
   PHYAddress: 0
   Pause RX: false
   Pause TX: false
   Supported Ports: TP
   Transceiver:
   Wakeon: None
While not relevant for this issue; Upgrade drivers, reboot
[root@esxi2:/vmfs/volumes/661148bc-c11d7ae0-14ce-d85ed369312c/intel] esxcli software component apply -d /vmfs/volumes/hddds00/intel/Intel-i40en_2.7.2.0-1OEM.700.1.0.15843807_22938502.zip
Installation Result
   Components Installed: Intel-i40en_2.7.2.0-1OEM.700.1.0.15843807
   Components Removed: Intel-i40en_1.11.1.31-1vmw.703.0.20.19193900
   Components Skipped:
   Message: The update completed successfully, but the system needs to be rebooted for the changes to be effective.
   Reboot Required: true
all upgraded to vmware spec; firmware 9.4 / driver 2.7.2.0
   Current Message Level: 0
   Driver Info:
         Driver: i40en
         Version: 2.7.2.0
   Link Detected: true
   Link Status: Up
   PHYAddress: 0
   Pause RX: false
   Pause TX: false
   Supported Ports: TP
   Transceiver:
   Wakeon: None
The ESX v7 hosts are using the same DevID card (15FF) as the v8 hosts.  Intel's own instructions say to upgrade the firmware first, then the driver.
Outside of ESX, I booted to a debian live CD and had the same problem (see attached). this does not appear to be an issue with esx.
Outside of Debian, I ran this on a TrueNAS Scale machine with the same issue
root@truenas01[/tmp/intel/700Series/Linux_x64]# ./nvmupdate64e
01) Intel(R) Ethernet Controller X710   8.80(8.50)   15FF 00:025 Update not
02) Intel(R) Ethernet Controller        8.48(8.30)   1589 00:202 Update not
Here's the information on the x710 NICs in my TrueNAS server;
root@truenas01[/tmp/intel/700Series/Linux_x64]# ethtool -i enp25s0f0
driver: i40e
version: 6.1.55-production+truenas
firmware-version: 8.50 0x8000be1e 1.3082.0
expansion-rom-version:
bus-info: 0000:19:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
root@truenas01[/tmp/intel/700Series/Linux_x64]# ethtool -i enp202s0f3
driver: i40e
firmware-version: 8.30 0x8000a9b7 1.2926.0
bus-info: 0000:ca:00.3
supports-test: yes
Given that this problem exists for us across operating systems, I don't think this is an issue with Debian Live CD, TrueNAS and ESX.
What other options do we have to get the Intel firmware updated to 9.4?
Fikri_Intel
Hi nkoconno,
Thank you for your response.
Based on the issue, would you be able to confirm with us the below inquiries:
1) Has ESXi 7 - Running on Gigabyte Hardware Board (successful upgrade)?
2) Has ESXi 8 - Running on SuperMicro Hardware Board (Failed, Device not found)?
3) Debian, TrueNAS is running on the same SuperMicro Hardware?
Along with that, please share the PBA of the adapter. You may refer to the link below on where to find the PBA number. Providing photos of the adapter focusing on the markings (white sticker) found on the physical card will be highly appreciated for us to double-check on it. The PBA consists 6-3 digit number located at the last part of the serial number. This would help us identify if you are using an Original Equipment Manufacturer(OEM) or retail version of Intel Ethernet Adapter.
Identify Your Intel® Network Adapter Model Using PBA Number
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-i-o/ethernet-products.html
Kindly advise.
Fikri_Intel
Fikri_Intel
Hi nkoconno,
Hope you are doing well.
Just wanted to follow up, we have not heard your response to the inquiry in the previous post.
Kindly let us know for further analysis.
Fikri_Intel
Fikri_Intel
Hi nkoconno,
This is regarding your enquiry above.
Since we have not seen any updates, we will be closing this forum case from our end.
Fikri_Intel
