20829 Discussions
Controladores para intel HD 605 legacy (Heredados)
vilereck
Quiero actualizar mi tarjeta grafica integrada y he notado que hay versiones mas recientes en la pagina oficial de intel, pero son para DCH y no son compatibles en mi caso,
Como puedo cambiar la configuración de legacy a DCH para poder actualizarlos?
O hay otra pagina para los controladores legacy?
Alberto_R_Intel
vilereck, Thank you for posting in the Intel® Communities Support.
Just to let you know, we only provide support in English language and currently, we are using a translation tool.
For this scenario, in order for us to provide the most accurate assistance on this matter, we just wanted to confirm a few details about your system:
What is the model of the Intel® processor?
What is the model of the motherboard?
If this is a laptop, what is the model of it?
Is there any particular reason why you need to update the graphics drivers on your system?
Which Windows* version are you using?
The computer you are making a reference to, is it in a home or in the work environment?
Please attach the SSU report so we can verify further details about the components in your platform, please check all the options in the report including the one that says "3rd party software logs":
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91600
Albert R.
vilereck
Es una Intel Pentium Silver J5005 CPU 1.50GHz
la placa base es HP 8431 PGUTF0A8JCZ153 version 00000
All in one HP 200 Intel
Alberto_R_Intel
vilereck, Thank you very much for providing that information and the picture.
In reference to your question, "Como puedo cambiar la configuración de legacy a DCH para poder actualizarlos?", actually, the Intel® Pentium® Silver J5005 processor works with the Intel® UHD Graphics 605, so you should be able to install the DCH drivers, unless the manufacturer of the computer has done some customization on their machine and it is using a different graphics controller, since there are also AMD drivers for your computer, the SSU report is needed to confirm that information.
Just to let you know, we always recommend to install the graphics driver provided by the manufacturer of the computer, since that driver was customized by them to work with your specific platform.
I looked on HP's website and the latest version of the graphics driver they have available for your platform is 26.20.100.7925 Rev.B, that should be the proper driver for your system since it was tested, customized and validated by HP:
https://support.hp.com/in-en/drivers/selfservice/swdetails/hp-200-g3-all-in-one-pc/19960941/swItemId/vc-260168-1
Since the Intel® processor on the computer works with Intel® UHD Graphics 605, you can also install the Intel® generic graphics drivers, keep in mind that they might or might not work with your system and once installed some of the features and functions advertised by HP will not work properly or will not work at all. As you can see there are DCH drivers listed there for you to install:
https://downloadcenter.intel.com/product/126788/Intel-UHD-Graphics-605
Albert R.
Alberto_R_Intel
Hello vilereck, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Albert R.
Alberto_R_Intel
Hello mvilereck, Since we have not heard back from you, we are closing the case, but if you have any additional questions, please post them on a new thread so we can further assist you with this matter.
Albert R.
