28519 Discussions
Inquiry function warnings for -stand flag
andreasskeidsvoll
The following minimal example
program main
  use, intrinsic :: iso_c_binding, only : c_sizeof
  implicit none
  integer :: int_bit_size = bit_size(1)
  integer :: int_sizeof = sizeof(1)
  integer :: int_storage_size = storage_size(1)
  integer :: int_c_sizeof = int(c_sizeof(1))
  print *, int_bit_size, int_sizeof
  print *, int_storage_size, int_c_sizeof
end program main
 gives the following warnings during compilation
main.F90(10): warning #7347: This intrinsic function in an initialization expression is not standard Fortran 2018   [STORAGE_SIZE]
main.F90(11): warning #7347: This intrinsic function in an initialization expression is not standard Fortran 2018   [C_SIZEOF]
when compiled with all combinations of ifx and ifort and the flags -stand f90 -stand f95, -stand f03, -stand f08 and -stand f18. It does not give any warnings when compiled without the -stand flags.
I have had a look at the Fortran 2018 standard, and cannot see why storage_size and c_sizeof should give warnings and not bit_size. The compilers also do not give warnings for sizeof, even though it's not part of the standard. Is there something wrong with these warning messages, or am I missing something?
Ron_Green
Agreed with Steve and FortranFan.  I see the bogus warning in our nightly builds as well.  We'll open a bug report.
FortranFan
Correction: see the comment below:
TL;DR:
  • Use `C_SIZE_OF` intrinsic in executable section of the code, not in initialization expression such as "integer :: int_c_sizeof = int(c_sizeof(1))"
  • Use `C_SIZE_OF` with named objects, not literal constants.  This is because the argument X to this function has to be an interoperable entity and thus it cannot be a constant such as '1'.
Try this out and see if you would avoid the warnings with it:
   use, intrinsic :: iso_c_binding, only : c_sizeof, c_int, c_size_t
   integer(c_int), parameter :: x = 1_c_int
   integer(c_size_t) :: int_c_sizeof
   int_c_sizeof = c_sizeof(x)
   print *, "int_c_sizeof  = ", int_c_sizeof
end
andreasskeidsvoll
Thank you for the response. You are right that using c_sizeof in an executable part of the code removes the warning. I would, however, like to define the integer byte size as a parameter that is reused in several parts of the code, without having to calculate it with a function each time.  You are probably also right that the c_sizeof warning might be because the argument is not a variable, although I still have to understand what it means for an entity to be interoperable.
Do you know why the warning for the storage_size function appears? There does not seem to be a requirement for interoperability in the standard, but does constants fall outside the definition of a data object? From 16.9.184 STORAGE_SIZE (A [, KIND]) in J3/18-007r1:
Arguments:
A    shall be a data object of any type. If it is polymorphic it shall not be an undefined pointer. If
     it is unlimited polymorphic or has any deferred type parameters, it shall not be an unallocated
     allocatable variable or a disassociated or undefined pointer.
FortranFan
@andreasskeidsvoll ,
Re: "I would, however, like to define the integer byte size as a parameter that is reused in several parts of the code, without having to calculate it with a function each time." -
  • after reviewing the PDF toward the standard again on my kid's iPad in between travel points just now, apologies - I take back what I wrote earlier (I will scratch my earlier comment, I wrote too soon).  Both `C_SIZEOF` and `STORAGE_SIZE` are permitted under specification inquiry in constant expressions provided each primary is a constant expression.  So I reckon the standard permits the following (note untested) which may be what you seek:
       use, intrinsic :: iso_c_binding, only : c_sizeof, c_size_t, c_int
       integer(c_size_t), parameter :: bits_c_int = c_sizeof(1_c_int)
       integer(c_size_t), parameter :: bits_default_integer = storage_size(1, kind=c_size_t)
    end
What version of Intel Fortran are you using?  Have you tried the latest, 2023.0.0 IFX?
andreasskeidsvoll
@FortranFan I'm using the 2023.0.0 ifx and 2021.8 ifort. I tried to follow your suggestion by changing the code to
program main
  implicit none
  print *, bits_c_int, bits_default_integer
end program main
but compilation still gives the warnings
main.F90(7): warning #7347: This intrinsic function in an initialization expression is not standard Fortran 2018   [C_SIZEOF]
main.F90(8): warning #7347: This intrinsic function in an initialization expression is not standard Fortran 2018   [STORAGE_SIZE]
As an additional point, I would like to use the integer bit/byte size to keep track of how much memory is used by integers in the Fortran part of the code. I would also prefer to use the default Fortran integer bit size determined by the compiler/compiler flags, without setting the integer kind in the code.
andrew_4619
The original code  compiles with no errors or warning using  "Intel® Fortran Compiler Classic 2021.7.0 [Intel(R) 64]"
What version are you using? I remember filing a bug report on "intrinsic function in an initialization expression" a long time ago but those got fixed.
andreasskeidsvoll
@andrew_4619 Interesting – I'm using ifort 2021.8.0 and ifx 2023.0.0.
Steve_Lionel
The compiler is incorrect in issuing these warnings - I agree with @FortranFan 's explanation above.
Ron_Green
Ron_Green
Bug ID is CMPLRLLVM-43356
Steve_Lionel
From the Fortran Discourse forum, the following code gives errors (not just standards warnings), where again the usage is a specification inquiry.
use,intrinsic:: ieee_arithmetic, only: ieee_support_standard
print *, [ ieee_support_standard(1e0), ieee_support_standard(1d0) ]
end program
Barbara_P_Intel
Thanks, @Steve_Lionel, love these short reproducers. Seems like a real constant should be acceptable. I filed a bug on this, CMPLRLLVM-43725.
Steve_Lionel
@Barbara_P_Intel , the problem isn't the constant, but the reference to the "specification inquiry" function - ieee_support_standard in my last post. These are allowed in constant expressions, but what qualifies as a specification inquiry isn't spelled out in the constant expression text but rather in the previous subsection on specification expressions.
Barbara_P_Intel
@Steve_Lionel Thank you for the clarification! I learn a lot from reading this Forum.
JohnNichols
Valued Contributor III
@Barbara_P_Intel , I just read this post.  It made me smile and my mind wandered.
Question 1, read in this sense should be red as that is how it is pronounced.
Question 2: I fixed a Format statement a minute ago, took me a minute to work out the dumb typing mistake, another smile.
    DO   1589   I=1,NJOIN
        WRITE(*,56)JNN(I),FXX(I),FYY(I),FMM(I)
56      FORMAT(20X,I10,3(10X,3F10.3))
1589 CONTINUE
Jim:  I will fix the continue, there is only one of me.
Question 3: Learning, the place not to learn is in a 65 foot yacht off the New South Wales coast in a blow, about 65 knots and the waves are about 30 feet high and you are on the foredeck, it is 2am, you are changing headsails, wire halyard in one hand, shackle in the other and the guy with you who is holding the head of the sail says, "I dropped the shackle key overboard".  You realize it is Easter and you forgive him, because you never do the shackles up more than hand tight.
Barbara_P_Intel
The 2 bug reports that Ron and I filed for issues on this thread are fixed in the compiler that was released this week as part of oneAPI HPC Toolkit 2023.1.
Please check it out!
andreasskeidsvoll
@Barbara_P_Intel Unfortunately, the minimal example I gave in the original post still gives the following warnings during compilation
$ ifx -c main.F90 -stand f18
when compiled with both
$ ifx -v
ifx version 2023.1.0
and
$ ifort -v
ifort version 2021.9.0
The warning is also present for the adapted code in this post.
Barbara_P_Intel
So sorry, my bad. It will be fixed in the next release planned for this summer, i.e. summer in the northern hemisphere, winter elsewhere.
JohnNichols
The equator is like the if statement that can take, -1, 0 and 1, summer and winter only occur on the ones that have an absolute value of 1, the equator has neither seasons and water does not swirl in the toilet bowl.
I realize it is a thin strip of the world, but a lot of people live there.
Barbara_P_Intel
Both bugs that were filed on this Forum thread are fixed in the compiler that was released last week as part of oneAPI HPC Toolkit 2023.2.
Please try it out!
