In several instances where I am passing an user-defined data(type) variable as a parameter to a subroutine, I get the following error message: "error #6633: The type of the actual argument differs from the type of the dummy argument." However, the user-defined data variable is explicitly declared in both the calling and the called subroutines. My feeling is that this is a BUG of the Intel Fortran compiler, because:
1. WhenI compile the code in DEBUG Win 32 I get many of the same error messages;
2. when I compile the code in DEBUG x64 I get less but the same error message;
3. When I compile the code in RELEASE mode, either for Win32 or x64, the code compiles, builds and works perfectly...!
Follows an example of the source code:
calling routine:
SUBROUTINE READ_CONT_RANDOM_VARIABLE_DATA (INPUT, CRV)
IMPLICIT NONE
INTEGER INPUT !INPUT FILE NUMBER
TYPE(CONT_RANDOM_VARIABLE),INTENT(INOUT) :: CRV
CALL CRV_PARAMETER_EVAL(CRV); !!!!!! THIS IS WHERE I GET THE ERROR MESSAGE !!!!!!...
END SUBROUTINE READ_CONT_RANDOM_VARIABLE_DATA
called subroutine:
SUBROUTINE CRV_PARAMETER_EVAL(CRV)
IMPLICIT NONE
END SUBROUTINE CRV_PARAMETER_EVAL
The evidence so far suggests that the compiler is correct.
http://software.intel.com/en-us/forums/showthread.php?t=86588&o=a&s=lr
I had also some problems with interface checking but this was concerning character variables passed with wild-cards in the dummy entries used in some old libraries formerly compiled with CVF and now ported to ifort. As suggested somewhere in this forum, I turned off the checking. Running the program never caused an error so far.
Greetings,
Johannes
Thank you for your replies: Here is some example
REAL T, P,... ... CALL DDTCI (1, T, RPDS, LGLSA, LGFR, YF, & XOM, XLAM, ITYP2P, : ZF, X, Y, Z, XW, YW, ZW, XY, XZ, AD, CDZ, S, LGSMTH, . THETAW, ISIDES, : LPOIN2, WORK1, WORK2, WORK3, WORK4, WORK5, : LGABRT)
SUBROUTINE DDTCI (NT, T, P, LGLSA, LGFR, YF, XOM, XLAM, ITYP2P, . ZF, X, Y, Z, XW, YW, ZW, XY, XZ, AD, CD, S, LGSMTH, : THTAWD, . ISIDES, NMAX, WORK1, WORK2, WORK3, WORK4, WORK5, . LGABRT)
REAL T, P,... DIMENSION T(*), P(*),...
this is the typical case where the function expects arrays, and the call is done with values and dimension 1.
It is produce by /warn:interfaces, this is part of diagnostics, turning it off, code compiles and runs correctly.
1/ indeed changes could be done to T, RPDS, etc. in the calling code, and turn them into array and back into values, now, I would rather not change this legacy code that is working and add more complexity to it.
2/ usage of !DEC$ ATTRIBUTES NO_ARG_CHECK :: dummy-arg-name would disable the checks for all calls to DDTCI, no? whereas I just want to turn off the checks for this call
3/ My issue is not so much how to fix the code, but how I can keep a high level of check on my solution (i.e. all /warn on) while disabling specific error/warning on some specific files where the code is too hard to fix without major rewrite
Thank you!
Show me an example call. If you are passing input values, you can enclose the scalar argument in [] and that turns it into an array. This won't work if the subroutine writes to the argument.
