16666 Discussions
How to create many similar assignments in just a few keystrokes
Do you have a bunch of design entities that you want to give the same assignment, but you don't want to enter them one by one in the Assignment Editor? Here's how you can make assignments to any number of design entities in just a few steps. Go to the assignment editor and put in your assignment name and value. Then, in the "To" column, use the node finder to select everything you want to have that assignment applied to. You can use the double arrow button to have everything in the nodes found window transferred to the nodes selected window. When you hit "ok", the assignment you first entered will be applied to everything you selected in the node finder.
Just used this trick to quickly assign an Output Enable group to a bunch of DDR signals. Thanks for the tip!
