16642 Discussions
Questa Intel FPGA edition crash.
ELIT1
Hi.
If you first add new signals to the waveform window and then restart the simulation, Questa will crash.
If you restart the simulation first and then add signals, everything will be fine.
I don't remember a similar problem with Modelsim.
RichardTanSY_Intel
Which operating system are you using? Please ensure that your operating system is supported.
You can check the list of supported operating systems here:
https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/os-support.html#editorialTableBlade-6
Are you able to duplicate the crash using the example design from this Quick Start user guide and following steps 1.8 and 1.9?
Questa*-Intel® FPGA Edition Quick-Start: Intel® Quartus® Prime Pro Edition user guide here:
https://www.intel.com/content/www/us/en/docs/programmable/691278/21-3/add-signals-to-the-simulation.html
Richard Tan
RichardTanSY_Intel
Richard Tan
ELIT1
Thanks a lot.
I use Windows 10 Pro, 22H2.
Design example works fine.
But I usually don't use simulation scripts, I create a simulation projects (.mpf).
There may be something that needs to be added to the simulation project.
I'll study the script from design example.
Thanks for the fast support!
ELIT1
RichardTanSY_Intel
Thank you for acknowledging the solution provided.
Now, I will transition this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out.
Thank you and have a great day!
Richard Tan
ELIT1
Hi.
To prevent this and possibly other problems when migrating from Modelsim to Questa, the simulation project must be rebuilt.
Unfortunately, I did not find how to rebuild the project automatically and had to create a new project.
After which everything works fine.
ELIT1
