Performance drop in dgetrf()
techwinder_
I'm distributing an app which links to MKL - amazing library btw, thanks.
A user has recently reported a significant performance drop in dgetrf_() when switching to a new computer with an Intel® Core™ i9-13950HX Processor.
Matrix size is ~27000. Typically the factorization should only take 2 minutes or so in multithreaded mode, however it can take up to 40 minutes on the new platform. When disabling in-app multitheading the LU factorization takes roughly 6 minutes which seems normal.
Adjusting MKL setttings with
MKL_Set_Num_Threads_Local();
MKL_Set_Dynamic();
doesn't make any significant difference.
After disabling efficient cores in the BIOS so that only the performance cores are enabled, the factorization time is back to a minute and a half.
Do you have any suggestions to address this issue without having to tweak the BIOS settings?
Thanks in advance,
André
noffermans
Hi André,
Thanks for reaching out. Are you aware of the below doc page?
https://www.intel.com/content/www/us/en/docs/onemkl/developer-guide-linux/2024-1/managing-performance-with-heterogeneous-cores.html
It gives some useful tips on how to manage performance with heterogenous CPUs, without having to play with the BIOS. I hope this helps.
Best,
Nicolas
noffermans
Hi André,
Best,
Nicolas
Fengrui
Hi André,
Did you get a chance to try the environment variables shared by Nicolas?
Fengrui
techwinder_
Yes, it fixed the problem for the user.
Thank you all for the quick support.
André
