FTP Server Can't List File
Hi, All!
The FTP server in the uClinux of our Nios II platform has worked successfully. But
when I use the FlashFXP ftp client to list the exist file in the ftp server, I can't
see anything. In actually, there are some files in the FTP server. If I access the FTP server in the MS-DOS mode, everything is OK!
Could anybody tell me WHY!!!
May i know how you access it in ms-dos prompt?
C:\Documents and Settings\JWLAM>ftp 192.168.1.12 Connected to 192.168.1.12. 220- Welcome to the uClinux ftpd! 220 uClinux FTP server (GNU inetutils 1.4.1) ready. User (192.168.1.12:(none)): ftp 500 'USER ftp': command not understood. Login failed. ftp> quit 500 'USER ftp': command not understood. C:\Documents and Settings\JWLAM>
i keep getting this error no matter wat i input. Pls advise.
Thx!
Msg06484
I got the iniche to work with the ucossi.
I am trying to start the FTP server.
I get strange answers such as
PS C:\Users\123> ftp 192.168.xxx.xxx
Connected to 192.168.xxx.xxx.
220 Service ready
500 Unsupported command
User (192.168.xxx.xxx:(none)): guest
Connection closed by remote host.
220 Service ready
User (192.168.xxx.xxx:(none)): anonymous
I am not sure why it is doing that.
I do not have any sample code to get this to work.
Essentially I figured out how to get the FTP_SERVER preprocessor define into the bsp, then added a call to ftps_init();
There may be more I need to do.
Any suggestions would help thanks.
Martin
--- Quote Start ---
originally posted by jwlam@Mar 2 2007, 12:06 AM
may i know how you access it in ms-dos prompt?
c:\documents and settings\jwlam>ftp 192.168.1.12 connected to 192.168.1.12. 220- welcome to the uclinux ftpd! 220 uclinux ftp server (gnu inetutils 1.4.1) ready. user (192.168.1.12:(none)): ftp 500 'user ftp': command not understood. login failed. ftp> quit 500 'user ftp': command not understood. c:\documents and settings\jwlam>
i keep getting this error no matter wat i input. pls advise.
thx!
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=21955)</div>
--- Quote End ---
In MS-DOS mode:
ftp 192.168.0.192
Connected to 192.168.0.192.
User (192.168.0.192:(none)): anonymous
331 Guest login ok, type your name as password.
Password:
230 Guest login ok, access restrictions apply.
ftp> ls
200 PORT command sucessful.
550 No files found.
ftp> quit
221 Goodbye.
ftp 192.168.1.12 Connected to 192.168.1.12. 220- Welcome to the uClinux ftpd! 220 uClinux FTP server (GNU inetutils 1.4.1) ready. User (192.168.1.12:(none)): anonymous 500 &#39;USER anonymous&#39;: command not understood. Login failed. ftp> quit 500 &#39;USER anonymous&#39;: command not understood.
i keep getting the &#39;command not understood&#39; error. mind to help me check if my settings below are correct?
/> netstat -a Active Internet connections (servers and established) Proto Recv-Q Send-Q Local Address           Foreign Address         State tcp        0      0 *:http                  *:*                     LISTEN tcp        0      0 *:ftp                   *:*                     LISTEN tcp        0      0 *:telnet                *:*                     LISTEN Active UNIX domain sockets (servers and established) Proto RefCnt Flags       Type       State         I-Node Path /> cat /etc/group root:x:0: ftp:x:50: /> cat /etc/passwd root:x:0:0:root:/:/bin/sh ftp:x:14:50:FTP User:/home/ftp: />
Thx!
hi ganssle,
i can login to the ftp server now. but i also cant list files. have u found any solution to that?
