Processors
14713 Discussions
Chipset 875P driver
Eva_J
I need a driver for the 875P chipset.
I need it on its own on a floppy or USB so that I can use the F6 method to install Windows 7 on a SATA hard disk. Where can I download it?
n_scott_pearson
Nothing like that will be available on the Intel site. Now, that is; you may be able to find it using the Wayback Machine's archive of the Intel site.
Hope this helps,
Eva_J
Thanks for the answer. Actually the problem solved itself when I happened to use another installation disk for W7. It included SP1, which might be why it worked without adding any extra drive.
Anyhow, I spent an interesting hour getting familiar with Wayback Machine! Might be useful sooner or later
/EJ
