Hi, EasterEggs.
Thank you for patiently waiting. We have received an update from our technical team regarding your concern. Upon investigating, we have several observations that we would like to share and ask with you. Kindly see the following:
- May we know the current version of the Intel XTU that you are using?
- To verify if you're using the latest version, kindly go to System Information and look for XTU. Kindly send a screenshot in this community thread so that we can confirm and validate.
- Have you already tried to uninstall and reinstall the Intel XTU manually?
- If not, kindly try to uninstall and reinstall the XTU as the latest version is 7.14.0.15. Here's the link where you can download the latest version of XTU: (https://www.intel.com/content/www/us/en/download/17881/intel-extreme-tuning-utility-intel-xtu.html)
- Reset bios to default and update the BIOS (https://www.msi.com/Motherboard/MAG-Z790-TOMAHAWK-WIFI/support) to the newest version.
Please let us know the update on any progress and changes of the issue so that we can further examine and investigate the issue.
Von M.
Hi, EasterEggs.
Thank you for posting in the Intel Communities. Let me help you with that.
Von M.
Hi, EasterEggs.
Thank you for patiently waiting. Upon coordination, We would like to confirm if the Intel extreme utility worked properly before? Since you've mentioned that the latest version of Intel Extreme Utility is not working with I5 13600K.
Also, according to our record, this application: (https://www.intel.com/content/www/us/en/download/17881/intel-extreme-tuning-utility-intel-xtu.html) can support Intel® Core™ i5-13600K Processor.
Just to share with you, we have our support link where you can find all of the troubleshooting steps that we’re going to perform. To make it easier for you, here’s our support link: (https://www.intel.com/content/www/us/en/support/articles/000089233/processors/processor-utilities-and-programs.html).
Kindly let us know if you have questions regarding the issue.
Von M.
Thanks for your answer!
As you can see on the screenshot enclosed, the previous version (7.12.0.29) works properly.
Thanks in advance.
Unfortunately I have exactly the same problem before the update everything worked and now the window remains empty
I too am having this problem with my brand new i5-13600k and msi mpg z690 DDr4 wifi motherboard.
once i click the button it says its not supported
Hi, EasterEggs.
Thank you for your reply. My apologies as I overlooked the community thread. Please be informed that we will do further research on this matter and post the response on this thread once available.
I understand that you have the same issue regarding the Intel Speed Optimizer that is not supported. However, to assist you more efficiently, it would be best to create your own thread. In this way, we can further help you if is there any possible troubleshooting steps that we can take to help fix the same issue.
Von M.
I have the same error with the latest version. It worked on 7.12.0.29 but doesn't work on any version since 7.14.0.15 to 7.14.1.12.
I see the Automatic Overclocking unsupported message and my BIOS is current.
Hi, EasterEggs.
Von M.
Thanks for your help!!
Now it's working with the last version of the Bios available since January 29th !!!
Big thanks to you.
Hi, EasterEggs.
That's good to hear! If you need any additional information, please submit a new question as this thread will no longer be monitored.
Von M.
Intel Customer Suppor Technician
