AI Tools from Intel
Find answers to your toolkit installation, configuration, and get-started questions.
openAPI and deep learning *plz hlp*
Anonymous
Not applicable
Can Intel devcloud oneAPI toolkits be used for AI and machine learning projects ( like images or music generators .) ??? Moreover, how do I select the hardware for my project, it says that a lot of powerful CPUs and GPUs are available so how can i choose which (cpu & gpu ) i wanna use ??? Cause I'm a beginner in the AI domain
JyothisV_Intel
Good day to you.
>> Can Intel devcloud oneAPI toolkits be used for AI and machine learning projects?
Yes, Intel DevCloud for oneAPI can be used for AI and machine learning projects.
>> Moreover, how do I select the hardware for my project, it says that a lot of powerful CPUs and GPUs are available so how can i choose which (cpu & gpu) I wanna use?
You need to enroll for Intel DevCloud for oneAPI with your email address. Follow the links below for steps on how to get started and documentation:
Get Started: https://devcloud.intel.com/oneapi/get_started/
Connect to Intel DevCloud for oneAPI: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-cygwin/
Requesting Hardware and Job Submission: https://devcloud.intel.com/oneapi/documentation/job-submission/
JupyterLab/Notebooks: https://jupyter.oneapi.devcloud.intel.com/hub/login?next=/lab/tree/Welcome.ipynb?reset
Do get back to us if you need any further assistance. If this resolves your query, kindly mark this as a solution as it will help others with a similar query.
Jyothis V James
JyothisV_Intel
Good day to you.
Jyothis V James
JyothisV_Intel
Good day to you.
Thanks for accepting the solution. We will no longer monitor this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
Jyothis V James
