I am doing performance work for my company but I can't seem to get µPipe to show up, instead I get this:
Running the same program on a different computer (intel i7-8086k), I see the µPipe graphs.
What am I doing wrong? What can I do to get VTune to show it?
I've attached the self checker log to this post.
Thanks in advance.
It looks like the uarch-exploration test is good from the log. Could you share the VTune data?
Did you capture the uarch using the sample code inside VTune installation path below and see if the same issue is observed?
/opt/intel/oneapi/vtune/latest/samples/en/C++/matrix
I just did, I get the same type of result.
Did you try another analysis type? like hotspots HW or SW sampling mode? Does it work fine? You can check if your local environment has some restrictions:
HW SAMPLING COLLECTION CONFLICT DUE TO WINDOWS DEFENDER VIRUS PROTECTION (DOC-10966)
Apologies for the late response, I was away. The other analysis types seem to work fine. I will check the restrictions and defender, thank you.
