Analyzers
5307 Discussions
μarch bottom up tab has a bad speculation metric that does not match event or summary views
TyL8
I believe this question has been asked before, but the OP no longer responded:
https://community.intel.com/t5/Analyzers/Weird-result-when-testing-Cinebench2024-and-COMSOL/m-p/1522184/thread-id/23870
I am trying to profile PCSX2, a PlayStation 2 emulator. I'm finding that some functions have moderate to high levels of bad speculation due to "Machine Clears."
The summary of my sample shows 0.0% machine clears:
More interestingly, I'm reading that there should be three related events
MACHINE_CLEARS.COUNT
MACHINE_CLEARS.MEMORY_ORDERING
MACHINE_CLEARS.SMC
I can only find MACHINE_CLEARS.COUNT in the event view and as seen below when sorting by descending order there are a total of 0 machine clears during my entire sample.
I have tried the full finalization mode and have invoked VTune finalization from the command line with AMPLXE_SAMPLES_TO_LOAD=0 with no success.
Attached is my entire sample folder zipped.
I would like to know if the machine clears are actually happening, or if I should consider the machine clear metric in the bottom up view to be incorrect.
Note: A reproducible executable might will be difficult to produce, but it's not impossible.
Ty Lamontagne
yuzhang3_intel
I am not sure if it is one bug, the platform is too old. But you can customize the uarch-exploration and add the other two related machine clear events for monitoring, try again.
yuzhang3_intel
TyL8
Thanks, I totally forgot that you can create your own analysis.
Good news, after enabling those events, and bringing the "Sample After" number way down, I can see the cause of the machine clears.
Thanks!
