Analyzers
5028 Discussions
9.1 CentOS 5.2 Run Issue
uponone
I've recently installed 9.1 on CentOS 5.2. I added my login ID to the vtune group and still get the permission error for the global_data directory. Has anyone else run into this issue?
uponone
Quoting - uponone
Nevermind, I had to reboot the OS in order for it to work.
TimP
Quoting - uponone
Quoting - uponone
logoff should be sufficient.
Peter_W_Intel
Quoting - uponone
you can try "export VTUNE_GLOBAL_DIR=/tmp" for example, assume that you have write-permission to that directory.
Regards, Peter
