Analyzers
5228 Discussions
Advisor Survey & Roofline - incompatible database schema
Jones__Brian
I ran Advisor survey and roofline reports on four different programs. I ran the report on Linux in the cloud, then downloaded the results to examine locally using the Windows GUI.
In the Survey & Roofline tab, all four programs say:
No Data
Data loading failed
Error message: incompatible database schema
I have attached a png showing the message.
The other reports have no problems like that.
I am running Advisor 2020 Update 2 on Windows 10.
Why am I getting that message?
RaeesaM_Intel
Thank you for posting in Intel Forum.
This is mainly due to the version incompatibility issue.
Could you please try with the same version of advisor that you use in linux or update to the latest version. Advisor works fine if the version on windows is same or higher than the version on linux.
Raeesa
RaeesaM_Intel
Raeesa
Jones__Brian
Thanks for your reply.  That did fix the problem.
RaeesaM_Intel
Thank you for the confirmation. We are discontinuing monitoring this thread . Please raise a new query in case if you encounter any further issues.
Raeesa
