Analyzers
Amplxe-gui 2017 crashes when finalizing diskio results
Teodor_H_
Hi
VTune crashes when finalizing results for diskio analysis. Analysis runs properly, however on finalizing results it crashes when loading 'stdsrc.etl'
Attached is the crash log generated by application. I can share the analysis results if you need them.
Teodor
Kevin_O_Intel1
I can file a bug report.
Can you give me some additional information? What type of analysis were you running?
Can you run
amplxe-feedback -create-bug-report test
This will create a test.zip file ... Can you attach this fle
Kevin
Teodor_H_
Hi Kevin,
I was running a diskio analysis.
I get the following error while running amplxe-feedback
C:\temp>amplxe-feedback -create-bug-report test
Intel(R) VTune(TM) Amplifier XE 2017 (build 478468) feedback tool
Copyright (C) 2009-2016 Intel Corporation. All rights reserved.
Collecting pids tree
C:\temp>/*  2>nul 1>nul
Copyright (C) 2006-2010 Intel Corporation. All rights reserved.
Quality Feedback Agent
Version: Quality Feedback Agent for Windows*
This diagnostic script generates detailed information about your system.
When  you forward  the output of this command to Intel(R) Support, the enclosed
system data will be used solely for the purposes of troubleshooting the problem
you have reported to Intel(R) Support. This information will not be shared with
any other companies or users, nor will it be used for any other purpose.
The script is collecting info. Please wait ...
Hardware and OS Information
        * Collecting information about your system by systeminfo
        * Collecting information about your system by msinfo32
        * Getting events recorded in the Application log
        * Getting events recorded in the Security log
        * Getting events recorded in the System log
        * Getting user's properties
        * Exporting the Local Security Policy settings
        * Installed Products
Product specific information
        * Product components
        * Product installation directory
        * Product version
        * Sep file version
        * Intel(R) Software Product licenses
        * Product settings from the system registry
        * Copying product install logs
        * Collecting list of product files
Exception occurred: [object Error]
C:\Users\THANCH~1\AppData\Local\Temp\amplxe-log-thanchevici\2016-09-16-11-34-44-543.amplxe-feedback.exe\qfagent.cmd(452, 5) Microsoft JScript runtime error: Invalid procedure call or argument
CScript Error: Execution of the Windows Script Host failed. (0x80020102)
C:\temp>
Will the report file generated by VTune help?
regards,
Teodor
Teodor_H_
Maybe these files help
Kevin_O_Intel1
Thanks!
I'll discuss these issues with our development team and get back to you
Kevin
Kevin_O_Intel1
Can you also attach the full result directory that VTune generated.
Thanks!
Kevin
Teodor_H_
Hi Kevin,
the archive is 47MB, which seems too much for the web interface (errors at 47%). Do you have a public FTP where I can copy it?
Teodor
Kevin_O_Intel1
Can you create an Intel  premier support issue and attach the directory to the issue?
Kevin_O_Intel1
You could also try e-mail to kevin.p.oleary@intel.com
Teodor_H_
Hi Kevin,
I have sent you a mail with details on how to access the archive.
regards,
Teodor
Roman_S_Intel1
Hi Teodor,
To collect Disk I/O analysis metrics VTune Amplifier relies on data provided by low level Windows* OS layers. From the provided results we see that ETW reported incomplete configurations for SMC USB drives on your system. We will handle the case gracefully and include the fix to the future VTune Amplifier release.
Roman
