Hello
I cannot launch profiler in gui mode on my Windows.
The app shows its logo, but closes within a few seconds.
I've tried to open it in the console.
"vtune" worked perfectly, but "vtune-gui" showed the message below.
"Node.js HTTP port is not availableFailedTo Access Critical Module"
Any help is appreciated.
Thank you.
Ken
I am getting the exact same issue - VTune Profiler 2021.2, Windows 10 version 1909.
Running vtune-gui --log-to-console --log-level=debug returns the "port not available" line in Ken's post, as follows:
PowerShell wrote:
PS C:\Program Files (x86)\Intel\oneAPI\vtune\2021.2.0\bin64> .\vtune-gui.exe --log-to-console --log-level=debug
error: [Error: ENOENT: no such file or directory, open 'C:\Program Files (x86)\Intel\oneAPI\vtune\2021.2.0\bin64\-1'] {
errno: -4058,
code: 'ENOENT',
syscall: 'open',
path: 'C:\\Program Files (x86)\\Intel\\oneAPI\\vtune\\2021.2.0\\bin64\\-1'
VTune GUI requires IPv4 and the loopback adapter. Please check that none of those is disabled:
ping 127.0.0.1
or:
netsh interface IPv4 show interfaces
The last command should list Loopback interface and the state should be Connected, like this:
Idx Met MTU State Name
1 75 4294967295 connected Loopback Pseudo-Interface 1
I have run both commands and can verify that there does not appear to be a problem.
Pinging localhost gives the expected, <1ms 0% loss result, while the IPv4 interfaces list the Loopback interface you described (numbers match exactly).
Hi
Thank you for your reply.
I just ran both commands and got exactly same results as Nick mentioned.
Thanks for the update.
We were not able to reproduce your issue.So could you share your complete error log as a separate file?
In the meantime you can also install and try the latest standalone vtune profiler 2021.3.0 from https://software.intel.com/content/www/us/en/develop/articles/oneapi-standalone-components.html#vtune
Janani Chandran
Is your issue resolved?
If not could you share the complete error log?
Janani Chandran
We assume that your issue is resolved.If you need any additional information, please submit a new question as this thread will no longer be monitored.
Janani Chandran
