Analyzers
5034 Discussions
Cannot build Intel Sampling Drivers (error: passing argument 1 of ‘class_create’ ...)
AckoftOvak
VTune 2023.1.0
Manjaro 23.0.0
Linux 6.4.3
GCC 13.1.1
user@hostname:/opt/intel/oneapi/vtune/latest/sepdk/src
$ sudo ./build-driver
C compiler to use: [ /sbin/gcc ]
C compiler version: 13.1.1
Make command to use: [ /sbin/make ]
Make version: 4.4.1
Kernel source directory: [ /lib/modules/6.4.3-1-MANJARO/build ]
Kernel version: 6.4.3-1-MANJARO
Cleaning workspaces ...
Done
Building socperf driver ...
In file included from ./include/linux/linkage.h:7,
                 from ./arch/x86/include/asm/cache.h:5,
                 from ./include/linux/cache.h:6,
                 from ./include/linux/time.h:5,
                 from ./include/linux/stat.h:19,
                 from ./include/linux/module.h:13,
                 from /opt/intel/oneapi/vtune/2023.1.0/sepdk/src/socperf/src/socperfdrv.c:61:
/opt/intel/oneapi/vtune/2023.1.0/sepdk/src/socperf/src/socperfdrv.c: In function ‘socperf_Load’:
./include/linux/export.h:27:22: error: passing argument 1 of ‘class_create’ from incompatible pointer type [-Werror=incompatible-pointer-types]
   27 | #define THIS_MODULE (&__this_module)
      |                      struct module *
/opt/intel/oneapi/vtune/2023.1.0/sepdk/src/socperf/src/socperfdrv.c:1738:34: note: in expansion of macro ‘THIS_MODULE’
 1738 |         pmu_class = class_create(THIS_MODULE, SOCPERF_DRIVER_NAME);
In file included from ./include/linux/device.h:31,
                 from ./include/linux/cdev.h:8,
                 from /opt/intel/oneapi/vtune/2023.1.0/sepdk/src/socperf/src/socperfdrv.c:69:
./include/linux/device/class.h:230:54: note: expected ‘const char *’ but argument is of type ‘struct module *’
  230 | struct class * __must_check class_create(const char *name);
/opt/intel/oneapi/vtune/2023.1.0/sepdk/src/socperf/src/socperfdrv.c:1738:21: error: too many arguments to function ‘class_create’
./include/linux/device/class.h:230:29: note: declared here
cc1: some warnings being treated as errors
make[3]: *** [scripts/Makefile.build:252: /opt/intel/oneapi/vtune/2023.1.0/sepdk/src/socperf/src/socperfdrv.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[2]: *** [Makefile:2026: /opt/intel/oneapi/vtune/2023.1.0/sepdk/src/socperf/src] Error 2
make[1]: *** [Makefile:145: default] Error 2
make: *** [Makefile:210: default] Error 2
Failed to build the drivers
AthiraM_Intel
The issue may be because you are using an unsupported platform. Could you please refer the system requirements and try to use any supported OS.
https://www.intel.com/content/www/us/en/developer/articles/system-requirements/vtune-profiler-system-requirements.html
 If you have any further issue, please let us know.
AckoftOvak
I am so happy with this answer. Great job! Thank you so much for your help! I always knew I can rely on Intel. You are the best, guys.
AthiraM_Intel
We believe that upon using a supported version of OS from the list (https://www.intel.com/content/www/us/en/developer/articles/system-requirements/vtune-profiler-system-requirements.html), the issue will not reoccur. If you are running into issues after moving to a supported version of OS, please let us know and we can continue troubleshooting.
AckoftOvak
Right, changing the OS is an easy solution. No worries, I will fix your bug.
AthiraM_Intel
We are sorry for the inconvenience caused. If you are facing any issue after moving to a supported version of OS, please post a new question as this thread will no longer be monitored by Intel.
AckoftOvak
You are not. If you were, you would have fixed it. It's a half an hour work.
I got it from the first time. What is your purpose of rubbing it in?
Fine with me. Buy.
superlupo
replace
with
pmu_class = class_create(SOCPERF_DRIVER_NAME);
And maybe think about buying Intel again
