Analyzers
5279 Discussions
Context Switch
Ami_Marowka
Is it possible to observe how many context switches were performed per run/per thread/per core with Intel VTune Amplifier XE for Windows?
Thanks in Advance
Ami
Peter_W_Intel
I suggest you to use L1 DTLB misses event to measure small page fault, and L2DTLB misses event to measure large page fault.
Regards, Peter
Hagen_G_
Hi Peter,
I am also interested in this measure. I have tried a Nehalem general exploration. On the screen where you push the "Start" button it lists "DTLB_MISSES.ANY" in the event table. However, after having performed the analysis, I don't find a DTLB measure anywhere in the results table. Can you help me how to access that information?
Regards, Hagen
Bernard
Valued Contributor I
I think that number of context switches is not measured by any hardware counter.You can include in profiling OS system files(ntoskrnl.exe) and look for NtSwapContext function on the top every thread's stack.Of course it will give a very crude estimation of exact number of context switches.
Bernard
@Ami
Xperf tool will give an exact number of context switches.
David_A_Intel1
Hey, guys!
Just check out the documentation, here and here! ;)
Synchronization Context Switches
Synchronization Context Switches metric measures the number of times a thread was switched off a processor because of making an explicit call to thread synchronization API. For example, in case of trying to wait on a synchronization object already occupied by another thread, the number of synchronization context switches will characterize the level of contention between threads.
This metric is available in the Hardware Event Counts viewpoint if you enabled the Collect stacks option during the hardware event-based sampling analysis configuration.
Preemption Context Switches
Preemption Context Switches metric measures a number of times the operating system task scheduler switched a thread off a processor to run another, higher-priority thread.
Then view the results and use the grouping control:
Bernard
@MrAnderson
Thank you for that valuable information.Now I can see context switching count from within VTune without the need to use additional tools.
Peter_W_Intel
Hagen G. wrote:
Hi Peter,
Regards, Hagen
General exploration analysis cannot include all events...you can use command line directly like as below, then use amplxe-gui to open result.
amplxe-cl -collect-with runsa -knob event-config=CPU_CLK_UNHALTED.CORE,DTLB_MISSES.ANY -- your-app
David_A_Intel1
I think Hagen G. meant that the event *is* collected by GE, but is not displayed in the table.
@Hagen. B, this may be a viewpoint issue.  By default, the General Exploration analysis type uses the General Exploration viewpoint, attempting to highlight potential efficiency issues in your code.  If you want to look at the actual events, you can switch to either the Hardware Event Counts or Hardware Event Sample Counts viewpoint.  For example,
