Analyzers
Community support for Analyzers (Intel VTune™ Profiler, Intel Advisor, Intel Inspector)
4925 Discussions
Docker environment, hotspot in "Hardware Event Based Sampling" can not finish
IvorySeagull
I ran the application and vtune both in the docker container.
Here is the command which I started the docker
docker run -dt --name=vtune-test --cap-add CAP_SYS_ADMIN --publish 8189:8189 --cpuset-cpus=0-31 --cpuset-mems=0 -v $HOME/vtune-test:/vtune-test intel/oneapi-basekit
Then I started the vtune backend by the command:
nohup vtune-backend --allow-remote-ui --web-port=8189 --enable-server-profiling --data-directory="/vtune-test" &
I set analysis configuration in the picture below:
The third parameter means that the application ends in 1 second.
But the analysis ran for about 30 minutes and didn't come to an end.
Need some help.
RemyaP_Intel
Could you provide us with the below information to assist you further :
  1. A sample reproducer code that we can use to replicate the issue from our side.
  2. OS details and VTune version
Remya Premdas
RemyaP_Intel
We haven't received any response from your end. Could you please share the details?
Remya Premdas
RemyaP_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question
Remya Premdas
