Analyzers
Community support for Analyzers (Intel VTune™ Profiler, Intel Advisor, Intel Inspector)
4922 Discussions
Does Vtune 8.0 for Linux support Dual Core Itanium2 porcessor?
robbie_j
Does Vtune 8.0 (or the lates) for Linux support Dual Core Itanium2 porcessor? BTW, my target kernel is 2.6.5.
Ekaterina_L_Intel
VTune 8.0.1 released in July, 2006 does support Dual-Core Intel Itanium 2 processor 9000 sequence.
The build #449 can be downloaded from premier.intel.com.
File: vtune_linux_8.0.1.449.tar.gz
Katya
robbie_j
Then how about Version vtune_linux_8.0.245.tar.gz?
Does it also support Dual-Core Intel Itanium 2 processor 9000 sequence?
Ekaterina_L_Intel
No, the build 8.0.245 doesn't support Dual-Core processors - the processors weren't public on the moment of the release (Oct 2005).
The support is available only since VTune 8.0.1 release.
BTW If you havelicense for 8.0 version - it will work with 8.0.1 as well.
Katya
robbie_j
Hi Katya,
Thank you for this valuable information. Finally I managed to download the 8.0.1 version.
Jie
Amit_N_Intel
Hi Katya,
In case of dual core machines with dual core processors, should there be two instances of vtune_drv.
My system has 2 dual core Xeons.
I have a feeling that sometimes, VTune is not sampling the right CPU on which the process is running.
I am running VTune 9.0
AN
