I am running vtune 2022.1 on a centos7 machine to analyze the hotspot consumption of a business process. When I run the hotspot collection, the resulting data file is corrupted. This error occurs many times
Some background info:
$ uname -a
Linux tlinux2-2 3.10.107-1-tlinux2_kvm_guest-0049 #1 SMP Tue Jul 30 23:46:29 CST 2019 x86_64 x86_64 x86_64 GNU/Linux
$ vtune --version
Intel(R) VTune(TM) Profiler 2022.1.0 (build 621966) Command Line Tool
Copyright (C) 2009-2021 Intel Corporation. All rights reserved.
Here is the error:
$ date && vtune -run-pass-thru=--no-altstack -collect hotspots -duration 300 -target-pid 4110 && date
2022-05-09 15:13:20 CST
vtune: Warning: Hardware collection of CPU events is not possible on this system. Microarchitecture performance insights will not be available.
vtune: Collection started. To stop the collection, either press CTRL-C or enter from another console window: vtune -r /data/home/nadoo/data/r001hs -command stop.
vtune: Collection detached.
vtune: Collection stopped.
vtune: Using result path `/data/home/nadoo/data/r001hs'
vtune: Executing actions 12 % Loading '32647-4110.0.trace' file
vtune: Error: Cannot load data file `/data/home/nadoo/data/r001hs/data.0/32647-4110.0.trace' (Data file is corrupted).
vtune: Executing actions 100 % done
vtune: Error: 0x40000025 (Inapplicable report) -- The report 'summary' is not applicable to the result /data/home/nadoo/data/r001hs/r001hs.vtune.
I found that every time this kind of data corruption error occurs, the business process disappears abnormally, by adding an audit rule that audits the kill operation in the audit service:
$ auditctl -a exit,always -F arch=b64 -S kill -S tkill -S tgkill -F a1!=0 -k my_audit_event
Part of the audit log:
$ ausearch -k my_audit_event |grep opid=4110 -C 5 |more
time->Mon May 9 15:13:21 2022
type=OBJ_PID msg=audit(1652080401.960:5240822): opid=4110 oauid=1000 ouid=1000 oses=168341 ocomm="arenasvr"
type=SYSCALL msg=audit(1652080401.960:5240822): arch=c000003e syscall=234 success=yes exit=0 a0=100e a1=100e a2=0 a3=0 items=0 ppid=6267 pid=6290 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 ses=168341 tty=pts5 comm="pinbin" exe="/data/home/nadoo/intel/oneapi/vtune/2022.1.0/bin64/pinbin" key="my_audit_event"
type=OBJ_PID msg=audit(1652080401.960:5240823): opid=4110 oauid=1000 ouid=1000 oses=168341 ocomm="arenasvr"
type=SYSCALL msg=audit(1652080401.960:5240823): arch=c000003e syscall=234 success=yes exit=0 a0=100e a1=1183 a2=0 a3=0 items=0 ppid=6267 pid=6290 auid=1000 uid=1000 gid=1000 euid=10
type=OBJ_PID msg=audit(1652080401.960:5240824): opid=4110 oauid=1000 ouid=1000 oses=168341 ocomm="arenasvr"
type=SYSCALL msg=audit(1652080401.960:5240824): arch=c000003e syscall=234 success=yes exit=0 a0=100e a1=1184 a2=0 a3=0 items=0 ppid=6267 pid=6290 auid=1000 uid=1000 gid=1000 euid=10
Through the audit log, I found that the business process exited due to receiving a signal. This process '~/intel/oneapi/vtune/2022.1.0/bin64/pinbin' has many system calls, and system call 234 corresponds to #define __NR_tgkill 234 (reference: cat /usr/include/asm/unistd_64.h),
What is the process of 'pinbin', and why does it issue the command to kill the business process?
Thank you for posting in the Intel Communities.
As you mentioned, you are using Vtune 2022.1 on Centos 7, which is deprecated in this release, Intel® OneAPI 2022.1, and will be removed in a future release. So, could you please try it on a supported operating system and let us know?
System requirements link:
Jaideep
Hi, according to the list of supported operating systems, centos7.2 is supported.
$ cat /etc/centos-release
CentOS Linux release 7.2 (Final)
Nadoo
We informed our team to make changes to the documentation to avoid confusion. We tried to run a 5-minute application with the command you provided and it was running fine without any issues on Centos 7, and it took a few seconds to analyze the data. Please go through the attached screen shots.
Details :
OS : Linux (Centos7 distribution)
VTune Version: 2022.1
Could you please answer the following questions:
1. Are you trying to run your application inside of a VM?
2. Please, can you share the exact steps you followed and a sample reproducer (a sample application that is similar to the application you are trying to analyze)?
Jaideep
Could you please share the details mentioned above? so we can reproduce your issue from our end.
Jaideep
Jaideep
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Jaideep
