Analyzers
5000 Discussions
Error: The Survey results have been collected with different application parameters
EhabNasr
The software I'm using can generate different arguments each run which causes trouble running a survey and following it with trip-count (or any other analysis).
Is there a way I could get around this?
AthiraM_Intel
Could you please share the following details:
  1. OS and Hardware details
  2. Advisor version
  3. Sample reproducer code and exact steps you followed
Also please elaborate more about the issue.
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
AthiraM_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
EhabNasr
Hi sorry for the late reply. I've been able to work around it using the --ignore-app-mismatch flag.
Thanks a lot for your response!
Ruslan_M_Intel
Please keep in mind that your results could be inconsistent. Tripcounts collection uses Survey as a base. If behavior of you app changes from run to run the results could  be odd
