The software I'm using can generate different arguments each run which causes trouble running a survey and following it with trip-count (or any other analysis).
Is there a way I could get around this?
Could you please share the following details:
- OS and Hardware details
- Advisor version
- Sample reproducer code and exact steps you followed
Also please elaborate more about the issue.
We have not heard back from you. Could you please give us an update?
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Hi sorry for the late reply. I've been able to work around it using the --ignore-app-mismatch flag.
Thanks a lot for your response!
Please keep in mind that your results could be inconsistent. Tripcounts collection uses Survey as a base. If behavior of you app changes from run to run the results could be odd
