I first to use Vtune tool, At first ,I use "Fisrt Use Wizard" Wizard to run gsexample sample,and I get the error:
"Summary infomation can not be obtained"
How to solve the question ,help me
Thanks !
Please consider using "Sampling Wizard" and see if you continue to experience the issue. Also, it is important to ensure that the program runs long enough for VTune to capture enough sampling data. Try bumping up the runtime of the application, if possible.
Here is some additional information which may be helpful.
When running gsexample2a without any parameters, this problem can be encountered on some configurations. But a parameter needs to be passed to it.
Command Line: /opt/intel/vtune/samples/gsexample/gsexample2a
Usage: /opt/intel/vtune/samples/gsexample/gsexample2a
So, please pass /opt/intel/vtune/samples/gsexample/datafile.txt file as a parameter (or locate the file in your installation) to obtain the summary view.
Typical output from it may look like:
Line: /opt/intel/vtune/samples/gsexample/gsexample2a /opt/intel/vtune/samples/gsexample/datafile.txt
Processing '/opt/intel/vtune/samples/gsexample/datafile.txt' at Thu Sep 13 13:11:54 2008
Done at Thu Sep 13 13:12:04 2008
* Elapsed time was 10 seconds
* CRC calculated: 0x5
* File character count: 10126
* File processed 94938 times
* Total characters counted: 960430528
* Average characters/sec: 9.6043e+07
* Average loop iterations/sec: 9493.80
So, please try to specify a parameter to gsexample2a (2b, 3c) utilities.
Also, when gsexample2a is started without a parameter, and summary information is not obtained - because the application exits quite fast, and no samples might be collected (and in some cases might be) - thus no data for summary information window.
- Launched vtlec
- Clicked '+' button
- Clicked "First Use Wizard'
- Set the follwing fields to the following values:
Application to launch: /opt/intel/vtune/samples/gsexample/gsexample2a
Application arguments: /opt/intel/vtune/samples/gsexample/datafile.txt
Working directory: /home/knutel/workspace
- Clicked Finished
This was the output from the gsexample program:
Command Line: /opt/intel/vtune/samples/gsexample/gsexample2a /opt/intel/vtune/samples/gsexample/datafile.txt
Processing '/opt/intel/vtune/samples/gsexample/datafile.txt' at Tue Jan 27 17:32:11 2009
Done at Tue Jan 27 17:32:21 2009
* File processed 206990 times
* Total characters counted: 2093500416
* Average characters/sec: 2.0935e+08
* Average loop iterations/sec: 20699.00
Then the GUI works for a little while, then the Tuning Browser is updated with the following:
Sampling Activity
+--> (Date) Sampling Results
+--> Run 1
+--> CPU_CLK_UNHALTED.CORE
Then the dialog box pops up: "Summary infomation can not be obtained"
If I double-click on CPU_CLK_UNHALTED.CORE in the Tuning Browser, I get the same dialog box.
What gives?
More information:
Linux 2.6.27-7-server #1 SMP Fri Oct 24 07:20:47 UTC 2008 x86_64 GNU/Linux
Knute
I am running Vtunes on ubuntu 9.04.
Following the steps given in the startup guide, when i Run the gsexamople2a i get the error,
"Summary Information can not be obtained"
I tried runnig only sampling with out any application to launch, it genertated the summary with out errors.
Can any one help out with this error ?
Thanking you
Satish
Thanking you
Satish
