Analyzers
5340 Discussions
Error when running call graph wizard or First use wizard
mchibani
Hi all,
I have downloaded and successfully installed a non-commercial version of Vtune 9.1 for linux on ubuntu 7.10. However, when I try to run the provided samples (vtunedemo) only sampling runs correcty, when I try Call graph wizard or First use wizard it tells :
"ERROR: vtunedemo is not executable. Make sure it is your application."
How could I fix this.
Thanks in advance.
Ravi_V_Intel
Please check whether you are using the directory name (/opt/intel/vtune/samples/vtunedemo) or the actual executable file itself (/opt/intel/vtune/samples/vtunedemo/vtunedemo) - please note the name vtunedemo appears twice and it should appear twice when you are setting this as your Application to Launch.
srimks
New Contributor II
Quoting - mchibani
Hi all,
Thanks in advance.
Hi.
For " FIRST USE WIZARD", do perform following -
Application to Launch: [complete PATH with executable]
Application arguements: [arguement if needed by executable]
Working Directory: [PATH where executable has been build]
For "Call Graph", do perform following -
Do the same as above.
Please refer "Getting Started Guide", read it first and then execute as given for "First Use Wizard" & "Call-Graph".
It 'll be completely sucesful, if you read "Getting Started Guide" carefully.
~BR
mchibani
Thanx for the prompt response., but I still got the error.
The path is correct and the vtunedemo app runs perfectly in the command line. I went through the "Getting started" doc, but I found nothing related to my problem. As I understand, the demo should work out of the box, I even tried to recompile the demo but same result.
However, when I start vtune I got this messages before it starts :
/opt/intel/vtune/bin/Bistro.product: line 1: syntax error near unexpected token `newline'
/opt/intel/vtune/bin/Bistro.product: line 1: `export VT_BISTRO_EXTRALIBS_DIRS='
Is this related in some way to the error I get ?
Thomas_W_Intel
Quoting - mchibani
Bistro it the engine that instruments the binary for call-graph. It looks like something went wrong during the installation, because the path is not set correctly. I would re-install VTune in the hope that the path is set correctly next time.
Kind regards
Thomas
