Analyzers
5341 Discussions
Error while starting vtune profiler collection using root
vtune-work
I am trying to run vtune profiler from root user by,
=> source /opt/intel/oneapi/setvars.sh
After this I tried the command :
=> vtune -collect performance-snapshot sleep 5
ERROR :
[root@a1 opc]# vtune -collect performance-snapshot sleep 5
vtune: Error: The following events cannot be collected: UNC_M_CAS_COUNT.RD,UNC_M_CAS_COUNT.WR,UNC_M_PMM_RPQ_INSERTS,UNC_M_PMM_WPQ_INSERTS. Consider removing the events from the collection, loading the VTune Profiler sampling driver using the root credentials, or updating the OS kernel.
vtune: Collection failed.
And I tried to do the same collection using my normal user instead of root user, But then it worked. What changes should I make to make it work with the root user. Please help.
ShyamS_Intel
Could you please share your below information so that we can reproduce the issue from our end.
  • VTune version
  • Processor details
  • Operating system
Shyam Sundar
vtune-work
Vtune version : latest
Processor details :
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 20
On-line CPU(s) list: 0-19
Thread(s) per core: 2
Core(s) per socket: 10
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
BIOS Vendor ID: QEMU
CPU family: 6
Model: 106
Model name: Intel(R) Xeon(R) Platinum 8358 CPU @ 2.60GHz
BIOS Model name: pc-i440fx-4.2
Stepping: 6
CPU MHz: 2593.994
BogoMIPS: 5187.98
Virtualization: VT-x
Hypervisor vendor: KVM
Virtualization type: full
L1d cache: 32K
L1i cache: 32K
L2 cache: 4096K
L3 cache: 16384K
NUMA node0 CPU(s): 0-19
Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ss ht syscall nx pdpe1gb rdtscp lm constant_tsc arch_perfmon rep_good nopl xtopology cpuid tsc_known_freq pni pclmulqdq vmx ssse3 fma cx16 pdcm pcid sse4_1 sse4_2 x2apic movbe popcnt tsc_deadline_timer aes xsave avx f16c rdrand hypervisor lahf_lm abm 3dnowprefetch cpuid_fault invpcid_single ssbd ibrs ibpb stibp ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase tsc_adjust bmi1 avx2 smep bmi2 erms invpcid avx512f avx512dq rdseed adx smap avx512ifma clflushopt clwb avx512cd sha_ni avx512bw avx512vl xsaveopt xsavec xgetbv1 xsaves nt_good wbnoinvd arat avx512vbmi umip pku ospke avx512_vbmi2 gfni vaes vpclmulqdq avx512_vnni avx512_bitalg avx512_vpopcntdq la57 rdpid md_clear arch_capabilities.
Operating system : Oracle Linux Server release 8.6
ShyamS_Intel
Please run self checker commands using below commands and check drivers are installed correctly. Please share the self checker logs to us.
cd /opt/intel/oneapi/vtune/latest/bin64/ or <install-dir>/bin64
sh ./vtune-self-checker.sh
if needed please refer the documentation: https://www.intel.com/content/www/us/en/develop/documentation/vtune-help/top/installation/verify-linux-installation.html
Shyam Sundar
ShyamS_Intel
Could you please provide any updates.
Shyam Sundar
ShyamS_Intel
I assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Shyam Sundar
