Analyzers
5253 Discussions
Errors when generate the roofline model using Advisor via Devcloud.
Georgina
When I trying to generate the roofline model using Advisor via Devcloud, I am presenting the following errors:
advisor: Collection stopped.
advisor: Opening result 27 % Loading 'tripcounts_17838_0.tcs' file
advisor: Error: Cannot load data file `/home/u48261/test/vtune_rtm/complete/dpct_complete_code/e000/hs006/data.1/advixe-runtrc.txt' ().
advisor: Error: Cannot load data file `/home/u48261/test/vtune_rtm/complete/dpct_complete_code/e000/hs006/data.1/gtpin_msg.txt' ().
I am using the following command :
advixe-cl --collect=roofline --profile-gpu --project-dir=./ --search-dir src:r=src/ -- application_executable
One peculiarity is that, this command worked before in the same environment and executable application, but today do not work it.
Thank you.
YuliaE__Intel
Please clean project-dir before re-collection.
AthiraM_Intel
Could you please give us an update? Is your issue resolved?
AthiraM_Intel
We are assuming that the solution provided helped and would no longer be monitoring this issue. Please raise a new thread if you have further issues.
