Analyzers
5275 Discussions
Excel Report under VTune environment
Intel_C_Intel
Hi folks,
I am still evaluating VTune and I would like to export my data to Excel as proposed in the tools properties.
The point is that it does not want to work, the "Export Data To Excel" button is "greyed" I mean locked. So I want to know if it is a normal situation coming from the fact that my VTune is an evaluation version or maybe I have forgot to something.
Those who know something about it, please let me know.
David_A_Intel1
Note that there are two ways to export data for viewing in Microsoft Excel*:
1. File menu -> Export: this creates a comma-separated file with the data that can be imported into Excel.
2. The "Export Data to Excel" button that you refer to: which is only available if Excel is installed on the system.
Aries1
Is it possible to export data to excel using commandline?
Right now I do the sampling at commandline and view the result at GUI. Do I have to use the GUI to export the data into excel? Thanks.
David_A_Intel1
Yes. Using command line options, you can dump the data in CSV format, for example,
vtl view -processes -cd ","
Mr.Anderson
