Analyzers
Community support for Analyzers (Intel VTune™ Profiler, Intel Advisor, Intel Inspector)
Export HotSpot data?
duanetiemann
I'm running update 4 on linux (evaluation copy). I did a HotSpot analysis and I'd like to export the stack trace stats. I've heard that data can be exported to Excel, but I haven't found any way to do it. I'm sure I'm missing something obvious. Is there any way to export this data anywhere?
Thanks, Duane
David_A_Intel1
Hi Duane:
You can't get the stack info from the bottom-up view, but if you switch to the top-down you can export that data, which includes calling sequences.
Does this help? If not, what data is it you want to export and how do you want to use it? Thanks.
duanetiemann
That sounds like exactly what I want. I just don't see how to do it. I don't see anything in the file menu, etc.
Thanks, Duane
