Analyzers
Failed to finalize the result: the result you are opening is empty
dinesh_s_1
Event based sampling configurations are not working on my system (pls see details of system setup below).
With EBS, Vtune seems to be profiling for the duration but complains with the following error:
Things I have tried so far:
Added the source, binary and include directories as a part of the search directory (clicked on include subdirs as well).
clicked on re-resolve. None of these seem to help.
Machine setup
CPU: Intel XEON 5690. Events configured for CPU: Intel(R) Xeon(R) / Core i7 980X Processor
running 64-bit version of Vtune amplifier xe 2013. (amplxe-gui.)
OS: Ubuntu 10.04 LTS Linux Kernel version :  2.6.32-40.87.
Kernel modules were rebuilt with pax.ko, sep3_8.ko, and vtsspp.ko
In one of the prior posts in this forum for a similar error, someone from Intel had requested the output of amplxe-cl on /bin/ls. So I thought I would post it here.
amplxe-cl -collect hotspots -r /tmp/r002hs -- /bin/ls
Using result path `/tmp/r002hs'
Executing actions 33 % Resolving information for `ls'
Warning: Cannot match file `/bin/ls': checksum mismatch.
Warning: Cannot locate symbols for file `/bin/ls'.
Executing actions 50 % Generating a report
Summary
Elapsed Time:  0.002
CPU Time:      0
CPU Usage:     0
Executing actions 100 % done
Peter_W_Intel
You gave hotspot example, but you had the problem of EBS sampling. If vtune drivers are loaded,
Can you do -
1. amplxe-cl -collect lightweight-hotspots -duration 5 -r /tmp/r003lh
2. amplxe-cl -report hotspots -r /tmp/r003lh/
Regards, Peter
dinesh_s_1
output of command #1,
warning: On some systems based on the Intel microarchitecture code name Nehalem / Westmere with C-states enabled, this analysis type may cause system hanging due to a known hardware issue (see errata AAJ134 in http://download.intel.com/design/processor/specupdt/320836.pdf). To avoid this situation, disable all "Cn(ACPI Cn) report to OS" BIOS options before sampling with VTune Amplifier on such systems.
Using result path `/tmp/r003lh'
Executing actions  8 % Loading data files
Executing actions 34 % Resolving information for `libamplxe_sampling_logit_3.8.
Warning: Cannot locate symbols for file `/opt/intel/vtune_amplifier_xe_2013/lib64/libamplxe_sampling_logit_3.8.so'.
Executing actions 34 % Resolving information for `libpython2.6.so.1.0'
Warning: Cannot match file `/usr/lib/libpython2.6.so.1.0': checksum mismatch.
Warning: Cannot locate symbols for file `/usr/lib/libpython2.6.so.1.0'.
Executing actions 34 % Resolving information for `libgdk-x11-2.0.so.0.2000.0'
Warning: Cannot match file `/usr/lib/libgdk-x11-2.0.so.0.2000.0': checksum mismatch.
Warning: Cannot locate symbols for file `/usr/lib/libgdk-x11-2.0.so.0.2000.0'.
Executing actions 35 % Resolving information for `ib_ipoib'
Executing actions 35 % Resolving information for `rsyslogd'
Warning: Cannot match file `/usr/sbin/rsyslogd': checksum mismatch.
Warning: Cannot locate symbols for file `/usr/sbin/rsyslogd'.
Executing actions 35 % Resolving information for `libgtk-x11-2.0.so.0.2000.0'
Warning: Cannot match file `/usr/lib/libgtk-x11-2.0.so.0.2000.0': checksum mismatch.
Warning: Cannot locate symbols for file `/usr/lib/libgtk-x11-2.0.so.0.2000.0'.
Executing actions 35 % Resolving information for `libglib-2.0.so.0.2400.0'
Warning: Cannot match file `/lib/libglib-2.0.so.0.2400.0': checksum mismatch.
Warning: Cannot locate symbols for file `/lib/libglib-2.0.so.0.2400.0'.
Executing actions 35 % Resolving information for `amplxe-gui'
Warning: Cannot locate symbols for file `/opt/intel/vtune_amplifier_xe_2013/bin64/amplxe-gui'.
Executing actions 36 % Resolving information for `collectd'
Warning: Cannot match file `/usr/sbin/collectd': checksum mismatch.
Warning: Cannot locate symbols for file `/usr/sbin/collectd'.
Executing actions 36 % Resolving information for `bash'
Warning: Cannot match file `/bin/bash': checksum mismatch.
Warning: Cannot locate symbols for file `/bin/bash'.
Executing actions 36 % Resolving information for `libstdc++.so.6.0.13'
Warning: Cannot match file `/usr/lib/libstdc++.so.6.0.13': checksum mismatch.
Warning: Cannot locate symbols for file `/usr/lib/libstdc++.so.6.0.13'.
Executing actions 37 % Resolving information for `python2.6'
Warning: Cannot match file `/usr/bin/python2.6': checksum mismatch.
Warning: Cannot locate symbols for file `/usr/bin/python2.6'.
Executing actions 37 % Resolving information for `amplxe-runss'
Warning: Cannot locate symbols for file `/opt/intel/vtune_amplifier_xe_2013/bin64/amplxe-runss'.
Executing actions 37 % Resolving information for `libwx_gtk2-2.8.so.0.8.0'
Warning: Cannot locate symbols for file `/opt/intel/vtune_amplifier_xe_2013/lib64/libwx_gtk2-2.8.so.0.8.0'.
Executing actions 37 % Resolving information for `libgobject-2.0.so.0.2400.0'
Warning: Cannot match file `/usr/lib/libgobject-2.0.so.0.2400.0': checksum mismatch.
Warning: Cannot locate symbols for file `/usr/lib/libgobject-2.0.so.0.2400.0'.
Summary
output of command #2:
Just a bunch of app names and all 0s.
bash                                    0
_IO_acquire_lock_fct        libc-2.11.1.so                          0
_IO_default_finish        libc-2.11.1.so                          0
_IO_file_stat        libc-2.11.1.so                          0
_IO_file_xsgetn        libc-2.11.1.so                          0
_IO_fread        libc-2.11.1.so                          0
_IO_getline_info        libc-2.11.1.so                          0
_IO_new_fclose        libc-2.11.1.so                          0
libc-2.11.1.so                          0
___printf_fp        libc-2.11.1.so                          0
___vsnprintf_chk        libc-2.11.1.so                          0
___vsprintf_chk        libc-2.11.1.so                          0
__current_locale_name        libc-2.11.1.so                          0
__dcigettext        libc-2.11.1.so                          0
__disable_runtime
Peter_W_Intel
It seemed that you can use event-based sampling for system profiling. CPU time is zero - it did make sense because the processor was not busy then and sample count was limited. You can try to find captured samples (of clockticks):
amplxe-cl -report hw-events -r /tmp/r003lh/
So, now you can try EBS with your application:
amplxe-cl -collect lightweight-hotspots -duration 20 -r /tmp/r004lh -search-dir all:rp=project-dir -- application
What is output? Any error?
Can you use "amplxe-cl -report hw-events -r /tmp/r004lh/" to see report?
dinesh_s_1
Here is the output of collect-lightweight-hotpots command
Warning: On some systems based on the Intel microarchitecture code name Nehalem / Westmere with C-states enabled, this analysis type may cause system hanging due to a known hardware issue (see errata AAJ134 in http://download.intel.com/design/processor/specupdt/320836.pdf). To avoid this situation, disable all "Cn(ACPI Cn) report to OS" BIOS options before sampling with VTune Amplifier on such systems.
Using result path `/home/jvtapp/dinesh/r001lh'
Summary
Here is the output of the report:
Result directory does not contain data applicable to this report.
Error: Error 0x40000024 (Reporter error)
Nothing gets generated now.
Peter_W_Intel
It seemed that this problem is target application specific issue (system profiling is OK)
1. Have you tried latest VTune Amplifier XE 2013 Update 5?
2. Have you seen that your target app was running?
3. Is it possible that you can attach this binary? Or go https://premier.intel.com if you wont expose this app on public.
