Analyzers
Community support for Analyzers (Intel VTune™ Profiler, Intel Advisor, Intel Inspector)
4828 Discussions
False Positives: _mm_malloc and _mm_free
Nico_S_
Good day. Just started using Inspector (Update 2 build 550070).
After running Locate Memory Problems I always get false positives for _mm_malloc (memory leak) and _mm_free (missing allocation).
To verify the following code also reports false positives:
unsigned char *hostPtr = (unsigned char*)_mm_malloc((((1280 * 960) * sizeof(unsigned char)) + 63) & (-64), 4096);
hostPtr[100] = 0xFF;
_mm_free(hostPtr);
I don't want to just suppress the errors since to me it looks like Inspector should handle this correctly. Tested with malloc and free and Inspector works as expected.
How do I resolve this?
Rodolfo_N_1
Anyone looked into this yet?
Galimullin__Marsel
Hello! I have similar problem with  VirtualAlloc and VirtualFree.
When I build x86 version of a program, Inspector show me "Memory leak" in line of VirtualAlloc, but in x64 version all Ok.
My code:
#include <iostream>
#include <Windows.h>
#define VMALLOC(size) VirtualAlloc(NULL, size, MEM_COMMIT, PAGE_READWRITE)
#define VMFREE(p) VirtualFree(p, 0, MEM_RELEASE)
int main(int argc, char* argv[])
     SYSTEM_INFO sSysInfo;
     GetSystemInfo(&sSysInfo);
     const DWORD dwPageSize = sSysInfo.dwPageSize;
     void* mem = VMALLOC(dwPageSize);
     if (!mem)
          std::cout << "Failed to allocate memory" << std::endl;
          return -1;
     if (!VMFREE(mem))
          std::cout << "Failed to free memory" << std::endl;
          return -1;
     std::cout << "Done" << std::endl;
     return 0;
