Trying to profile an Unreal Engine 4-based application, suffering from rather frequent blue screens that are rendering this hopeless.
Unfortunately I can't get anything from the dump because I can't find kernel symbols (apparently I'm not alone https://social.msdn.microsoft.com/Forums/en-US/65db21ea-4c5b-4f24-ab26-0908479c977d/debug-symbols-for-4dac3b582a9147ecaed2644cb165222b1?forum=windbg ), so I'm not sure what else to say.
3: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* IRQL_NOT_LESS_OR_EQUAL (a) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses. If a kernel debugger is available get the stack backtrace. Arguments: Arg1: ffffe60fc9f58310, memory referenced Arg2: 0000000000000002, IRQL Arg3: 0000000000000000, bitfield : bit 0 : value 0 = read operation, 1 = write operation bit 3 : value 0 = not an execute operation, 1 = execute operation (only on chips which support this level of status) Arg4: fffff802da49f9be, address which referenced memory Debugging Details: ------------------ ***** Kernel symbols are WRONG. Please fix symbols to do analysis. ************************************************************************* *** *** *** *** *** Either you specified an unqualified symbol, or your debugger *** <SNIP> *** *** ************************************************************************* DUMP_CLASS: 1 DUMP_QUALIFIER: 401 BUILD_VERSION_STRING: 14393.447.amd64fre.rs1_release_inmarket.161102-0100 SYSTEM_MANUFACTURER: Gigabyte Technology Co., Ltd. SYSTEM_PRODUCT_NAME: To be filled by O.E.M. SYSTEM_SKU: To be filled by O.E.M. SYSTEM_VERSION: To be filled by O.E.M. BIOS_VENDOR: American Megatrends Inc. BIOS_VERSION: F1 BIOS_DATE: 10/24/2012 BASEBOARD_MANUFACTURER: Gigabyte Technology Co., Ltd. BASEBOARD_PRODUCT: Z77-HD4 BASEBOARD_VERSION: x.x ADDITIONAL_DEBUG_TEXT: You can run '.symfix; .reload' to try to fix the symbol path and load symbols. WRONG_SYMBOLS_TIMESTAMP: 5819bd1f WRONG_SYMBOLS_SIZE: 820000 FAULTING_MODULE: fffff802da410000 nt DEBUG_FLR_IMAGE_TIMESTAMP: 5819bd1f DUMP_TYPE: 1 BUGCHECK_P1: ffffe60fc9f58310 BUGCHECK_P2: 2 BUGCHECK_P3: 0 BUGCHECK_P4: fffff802da49f9be READ_ADDRESS: ************************************************************************* *** *** *** *** *** Either you specified an unqualified symbol, or your debugger *** <SNIP> *** *** ************************************************************************* Unable to get size of nt!_MMPTE - probably bad symbols ffffe60fc9f58310 CURRENT_IRQL: 0 FAULTING_IP: nt!KiCheckForKernelApcDelivery+fe fffff802`da49f9be 498b4a30 mov rcx,qword ptr [r10+30h] CPU_COUNT: 8 CPU_MHZ: d4b CPU_VENDOR: GenuineIntel CPU_FAMILY: 6 CPU_MODEL: 3a CPU_STEPPING: 9 CPU_MICROCODE: 0,0,0,0 (F,M,S,R) SIG: 1B'00000000 (cache) 0'00000000 (init) ANALYSIS_SESSION_HOST: TBS-BRADY ANALYSIS_SESSION_TIME: 11-16-2016 14:17:51.0735 ANALYSIS_VERSION: 10.0.14321.1024 amd64fre LAST_CONTROL_TRANSFER: from fffff802da565629 to fffff802da55a510 STACK_TEXT: ffff9481`76a06558 fffff802`da565629 : 00000000`0000000a ffffe60f`c9f58310 00000000`00000002 00000000`00000000 : nt!KeBugCheckEx ffff9481`76a06560 fffff802`da563c07 : 00000000`00000000 00000000`0004b000 ffff9481`76a06700 fffff802`da47a146 : nt!setjmpex+0x3ee9 ffff9481`76a066a0 fffff802`da49f9be : ffffe60f`c9f58000 fffff804`dfdf1786 00000000`00000282 ffffe60f`c9f0e000 : nt!setjmpex+0x24c7 ffff9481`76a06830 fffff802`da49f8e1 : ffffe60f`b7e47620 fffff802`da4ce500 ffffe60f`00000000 00000000`00000000 : nt!KiCheckForKernelApcDelivery+0xfe ffff9481`76a068c0 fffff802`da4ad057 : ffffe60f`c3f5b740 fffff802`da8deb28 fffff802`da74bab8 fffff802`da74bc98 : nt!KiCheckForKernelApcDelivery+0x21 ffff9481`76a068f0 fffff802`da8cc1a3 : ffffe60f`b7e47300 ffff9481`76a06980 00000000`00000000 fffff802`da8e199d : nt!FsRtlAcquireHeaderMutex+0x237 ffff9481`76a06940 fffff802`da8c76be : 00000000`00000000 ffffe60f`b7e47300 00000000`00000000 ffffe60f`c3f5b740 : nt!KeUserModeCallback+0x5b3 ffff9481`76a06a80 fffff802`da84c2a0 : ffffe60f`b7e47300 00000000`00000000 ffffe60f`b7e47300 00000000`00000000 : nt!FsRtlGetFileSize+0x19d2 ffff9481`76a06ac0 fffff802`da565193 : ffffe60f`b7e47300 ffff9481`76a06b80 00000000`00000010 ffffe60f`bd412710 : nt!IoOpenDeviceRegistryKey+0x148 ffff9481`76a06b00 00007ffb`34ec58c4 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!setjmpex+0x3a53 000000ec`804cf6c8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffb`34ec58c4 STACK_COMMAND: kb THREAD_SHA1_HASH_MOD_FUNC: 949bc9ed31f6f65b82927745a91c72095706179f THREAD_SHA1_HASH_MOD_FUNC_OFFSET: 44b1e75a0f8bfc03454e521c838a99d1b55f7d87 THREAD_SHA1_HASH_MOD: bc100a5647b828107ac4e18055e00abcbe1ec406 FOLLOWUP_IP: nt!KiCheckForKernelApcDelivery+fe fffff802`da49f9be 498b4a30 mov rcx,qword ptr [r10+30h] FAULT_INSTR_CODE: 304a8b49 SYMBOL_STACK_INDEX: 3 SYMBOL_NAME: nt_wrong_symbols!5819BD1F820000 FOLLOWUP_NAME: MachineOwner BUGCHECK_STR: 5819BD1F EXCEPTION_CODE: (NTSTATUS) 0x5819bd1f - <Unable to get error code text> EXCEPTION_CODE_STR: 5819BD1F EXCEPTION_STR: WRONG_SYMBOLS PROCESS_NAME: ntoskrnl.wrong.symbols.exe IMAGE_NAME: ntoskrnl.wrong.symbols.exe MODULE_NAME: nt_wrong_symbols BUCKET_ID: WRONG_SYMBOLS_X64_14393.447.amd64fre.rs1_release_inmarket.161102-0100_TIMESTAMP_161102-101703 DEFAULT_BUCKET_ID: WRONG_SYMBOLS_X64_14393.447.amd64fre.rs1_release_inmarket.161102-0100_TIMESTAMP_161102-101703 PRIMARY_PROBLEM_CLASS: WRONG_SYMBOLS FAILURE_BUCKET_ID: WRONG_SYMBOLS_X64_14393.447.amd64fre.rs1_release_inmarket.161102-0100_TIMESTAMP_161102-101703_5819BD1F_nt_wrong_symbols!5819BD1F820000 TARGET_TIME: 2016-11-16T18:59:48.000Z OSBUILD: 14393 OSSERVICEPACK: 0 SERVICEPACK_NUMBER: 0 OS_REVISION: 0 SUITE_MASK: 272 PRODUCT_TYPE: 1 OSPLATFORM_TYPE: x64 OSNAME: Windows 10 OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS OS_LOCALE: USER_LCID: 0 OSBUILD_TIMESTAMP: 2016-11-02 06:17:03 BUILDDATESTAMP_STR: 161102-0100 BUILDLAB_STR: rs1_release_inmarket BUILDOSVER_STR: 10.0.14393.447.amd64fre.rs1_release_inmarket.161102-0100 ANALYSIS_SESSION_ELAPSED_TIME: ffc ANALYSIS_SOURCE: KM FAILURE_ID_HASH_STRING: km:wrong_symbols_x64_14393.447.amd64fre.rs1_release_inmarket.161102-0100_timestamp_161102-101703_5819bd1f_nt_wrong_symbols!5819bd1f820000 FAILURE_ID_HASH: {d82425fb-28f9-fe3c-99c4-cbc6653270b1} Followup: MachineOwner ---------
With driver verifier, starting a project in VTune Amplifier triggers an immediate bugcheck due to vtss.sys
4: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* DRIVER_PAGE_FAULT_BEYOND_END_OF_ALLOCATION (d6) N bytes of memory was allocated and more than N bytes are being referenced. This cannot be protected by try-except. When possible, the guilty driver's name (Unicode string) is printed on the bugcheck screen and saved in KiBugCheckDriver. Arguments: Arg1: ffffaa0a0f4e9000, memory referenced Arg2: 0000000000000000, value 0 = read operation, 1 = write operation Arg3: fffff8026d76f9a9, if non-zero, the address which referenced memory. Arg4: 0000000000000000, (reserved) Debugging Details: ------------------ ***** Kernel symbols are WRONG. Please fix symbols to do analysis. ************************************************************************* *** *** *** *** *** Either you specified an unqualified symbol, or your debugger *** <snip> *** *** ************************************************************************* DUMP_CLASS: 1 DUMP_QUALIFIER: 401 BUILD_VERSION_STRING: 14393.447.amd64fre.rs1_release_inmarket.161102-0100 SYSTEM_MANUFACTURER: Gigabyte Technology Co., Ltd. SYSTEM_PRODUCT_NAME: To be filled by O.E.M. SYSTEM_SKU: To be filled by O.E.M. SYSTEM_VERSION: To be filled by O.E.M. BIOS_VENDOR: American Megatrends Inc. BIOS_VERSION: F1 BIOS_DATE: 10/24/2012 BASEBOARD_MANUFACTURER: Gigabyte Technology Co., Ltd. BASEBOARD_PRODUCT: Z77-HD4 BASEBOARD_VERSION: x.x ADDITIONAL_DEBUG_TEXT: You can run '.symfix; .reload' to try to fix the symbol path and load symbols. WRONG_SYMBOLS_TIMESTAMP: 5819bd1f WRONG_SYMBOLS_SIZE: 820000 FAULTING_MODULE: fffff802b1617000 nt DEBUG_FLR_IMAGE_TIMESTAMP: 5819bd1f DUMP_TYPE: 1 BUGCHECK_P1: ffffaa0a0f4e9000 BUGCHECK_P2: 0 BUGCHECK_P3: fffff8026d76f9a9 BUGCHECK_P4: 0 READ_ADDRESS: ************************************************************************* *** *** *** *** *** Either you specified an unqualified symbol, or your debugger *** <snip> *** *** ************************************************************************* Unable to get size of nt!_MMPTE - probably bad symbols ffffaa0a0f4e9000 FAULTING_IP: vtss+f9a9 fffff802`6d76f9a9 668b02 mov ax,word ptr [rdx] MM_INTERNAL_CODE: 0 CPU_COUNT: 8 CPU_MHZ: d4b CPU_VENDOR: GenuineIntel CPU_FAMILY: 6 CPU_MODEL: 3a CPU_STEPPING: 9 CPU_MICROCODE: 0,0,0,0 (F,M,S,R) SIG: 1B'00000000 (cache) 0'00000000 (init) CURRENT_IRQL: 0 ANALYSIS_SESSION_HOST: TBS-BRADY ANALYSIS_SESSION_TIME: 11-16-2016 15:11:22.0217 ANALYSIS_VERSION: 10.0.14321.1024 amd64fre LAST_CONTROL_TRANSFER: from fffff802b17b2a47 to fffff802b1761510 STACK_TEXT: ffff9780`95905e98 fffff802`b17b2a47 : 00000000`00000050 ffffaa0a`0f4e9000 00000000`00000000 ffff9780`95906190 : nt!KeBugCheckEx ffff9780`95905ea0 fffff802`b16bf5da : 00000000`00000000 00000000`00000000 ffff9780`95906190 ffff9780`959061e8 : nt!memset+0x453c7 ffff9780`95905f90 fffff802`b176aafc : 00000000`00000000 fffff802`b16ab54b ffffaa0a`00000001 fffff802`b1939d00 : nt!RtlRbRemoveNode+0x866a ffff9780`95906190 fffff802`6d76f9a9 : fffff802`6d76fda0 ffff9780`959063ea ffff9780`95906768 fffff3f9`fcfe7aa0 : nt!setjmpex+0x23bc ffff9780`95906328 fffff802`6d76fda0 : ffff9780`959063ea ffff9780`95906768 fffff3f9`fcfe7aa0 fffff3f9`fcfe7f38 : vtss+0xf9a9 ffff9780`95906330 fffff802`6d7700bb : 00700066`006d005c 0065002e`0070006d ffff0000`00650078 00000000`00012354 : vtss+0xfda0 ffff9780`95906630 fffff802`b1ae5ca3 : fffff802`b19528c8 ffff8184`26d32080 ffff8184`1de4d040 00000000`00000000 : vtss+0x100bb ffff9780`95906660 fffff802`b1afb829 : 00000000`0000000a ffff8184`265a8d10 ffff8184`26d32080 00007ffc`eba4cfff : nt!NtFindAtom+0x703 ffff9780`959066c0 fffff802`b1ad91e0 : ffff8184`1c78ddb0 00000000`00000000 ffff8184`271af800 ffff9780`959068c0 : nt!MmCopyVirtualMemory+0x1e89 ffff9780`95906820 fffff802`b1ad6b4f : ffff9780`95906900 ffff9780`00000008 ffff8184`19a77080 00000000`00000001 : nt!NtMapViewOfSection+0x2980 ffff9780`959069a0 fffff802`b176c193 : 00000000`0000003c ffff8184`19b1bcc0 000001d9`28105ec0 000001d9`28105e01 : nt!NtMapViewOfSection+0x2ef ffff9780`95906a90 00007ffc`ef405364 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!setjmpex+0x3a53 0000006c`94ace6c8 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : 0x00007ffc`ef405364 STACK_COMMAND: kb THREAD_SHA1_HASH_MOD_FUNC: 18d8a631bd219a5904ed130829606979a2544e24 THREAD_SHA1_HASH_MOD_FUNC_OFFSET: a47170e0300cde5ec6347f38fa16cc5931ab8a02 THREAD_SHA1_HASH_MOD: 46ffa982c1396e062fb0c183a98d68f0f84bb3df FOLLOWUP_IP: vtss+f9a9 fffff802`6d76f9a9 668b02 mov ax,word ptr [rdx] FAULT_INSTR_CODE: 66028b66 SYMBOL_STACK_INDEX: 4 FOLLOWUP_NAME: MachineOwner BUGCHECK_STR: 5819BD1F EXCEPTION_CODE: (NTSTATUS) 0x5819bd1f - <Unable to get error code text> EXCEPTION_CODE_STR: 5819BD1F EXCEPTION_STR: WRONG_SYMBOLS PROCESS_NAME: ntoskrnl.wrong.symbols.exe IMAGE_NAME: ntoskrnl.wrong.symbols.exe MODULE_NAME: nt_wrong_symbols SYMBOL_NAME: nt_wrong_symbols!5819BD1F820000 BUCKET_ID: WRONG_SYMBOLS_X64_14393.447.amd64fre.rs1_release_inmarket.161102-0100_TIMESTAMP_161102-101703 DEFAULT_BUCKET_ID: WRONG_SYMBOLS_X64_14393.447.amd64fre.rs1_release_inmarket.161102-0100_TIMESTAMP_161102-101703 PRIMARY_PROBLEM_CLASS: WRONG_SYMBOLS FAILURE_BUCKET_ID: WRONG_SYMBOLS_X64_14393.447.amd64fre.rs1_release_inmarket.161102-0100_TIMESTAMP_161102-101703_5819BD1F_nt_wrong_symbols!5819BD1F820000 TARGET_TIME: 2016-11-16T20:00:40.000Z OSBUILD: 14393 OSSERVICEPACK: 0 SERVICEPACK_NUMBER: 0 OS_REVISION: 0 SUITE_MASK: 272 PRODUCT_TYPE: 1 OSPLATFORM_TYPE: x64 OSNAME: Windows 10 OSEDITION: Windows 10 WinNt TerminalServer SingleUserTS OS_LOCALE: USER_LCID: 0 OSBUILD_TIMESTAMP: 2016-11-02 06:17:03 BUILDDATESTAMP_STR: 161102-0100 BUILDLAB_STR: rs1_release_inmarket BUILDOSVER_STR: 10.0.14393.447.amd64fre.rs1_release_inmarket.161102-0100 ANALYSIS_SESSION_ELAPSED_TIME: 46b11 ANALYSIS_SOURCE: KM FAILURE_ID_HASH_STRING: km:wrong_symbols_x64_14393.447.amd64fre.rs1_release_inmarket.161102-0100_timestamp_161102-101703_5819bd1f_nt_wrong_symbols!5819bd1f820000 FAILURE_ID_HASH: {d82425fb-28f9-fe3c-99c4-cbc6653270b1} Followup: MachineOwner ---------
What analysis and exact options you use when expereience the BSOD? Do you you have call count or/and trip count collection levels enabled?
Your system seems running the latest and greatest Windows Server 2016 OS which was relased on November. We are currently working on the OS support enabling in the next release of VTune Amplifier and will contact you once have an updated vtss.sys driver version for a fix verification.
Regards, Katya
Last one I encountered the issue one was
Advanced Hotspots
- Hotspots, call counts, and stacks
- Analyze user tasks, events, and counters
I could try dropping the settings down if that might help mitigate it.
This workstation is running Windows 10 Professional, not Windows Server 2016. It's got "feature updates" deferred, but that's as far as we've gone in slowing down updates so far. Should we do more to slow down updates on systems with VTune? Windows 10 is pretty aggressive with its updating.
Hello Brady,
We've sent you the vtss.sys driver updated version which has a potential fix for the problem. Did you have chance to try it?
Regads, Katya
