Analyzers
5269 Discussions
Highlighting wrong line number
Matous_S_
Dear community,
recently, I figured out that my Inspector Update 9 (build 328075) some times marks/highlights a wrong line number, e.g., for a found data race inside a try-block it marks the line with "try {".
What is the issue with that and what would be a solution to this problem?
Thanks and regards!
Peter_W_Intel
Usually I think about using disable optimization option to rebuild, recheck this.
It seemed that you used Inspector XE 2013. Please redo this with latest Inspector XE 2015 U1 -  build 366509.
Was is possible that you can provide inspector's result with data race errors on try_block?
