Analyzers
5201 Discussions
ICACHE.MISSES Parameter on Xeon-E5
Ayam
I am using intel xeon E5-24xx machine. When I try to read the parameter ICACHE.MISSES, most of the applications are reporting its values as 0. If I am not mistaken it is the Instruction cache misses of L1.
Please give me any idea how to check why this parameter is giving 0 value.
Peter_W_Intel
You may change default SAV to small value to capture more samples, I give you example:
# amplxe-cl -collect-with runsa -knob event-config=ICACHE.MISSES:sa=5000 -knob enable-stack-collection=true -- ./matrix2amplxe: Collection started. To stop the collection, either press CTRL-C or enter from another console window: amplxe-cl -r /home/peter/problem_report/r016runsa -command stop.
Elapsed time = 0.590000 seconds
amplxe: Collection stopped.
amplxe: Using result path `/home/peter/problem_report/r016runsa'
amplxe: Executing actions 16 % Resolving information for `ld-2.12.so'
amplxe: Warning: Cannot locate debugging symbols for file `/lib64/ld-2.12.so'.
amplxe: Executing actions 16 % Resolving information for `libc-2.12.so'
amplxe: Warning: Cannot locate file `vtsspp.ko'.
amplxe: Executing actions 16 % Resolving information for `vtsspp'
amplxe: Warning: Cannot locate debugging symbols for file `/lib64/libc-2.12.so'.
amplxe: Executing actions 17 % Resolving information for `libpthread-2.12.so'
amplxe: Warning: Cannot locate debugging symbols for file `/lib64/libpthread-2.12.so'.
amplxe: Executing actions 50 % Generating a report
Collection and Platform Info
Parameter                 r016runsa
Application Command Line  ./matrix2
Operating System          2.6.32-71.el6.x86_64 Red Hat Enterprise Linux Server release 6.0 (Santiago)
Computer Name             snb01.sh.intel.com
Result Size               1726725
Collection start time     23:05:56 08/04/2014 UTC
Collection stop time      23:05:56 08/04/2014 UTC
CPU
Parameter          r016runsa
Name               Intel(R) Core(TM) Processor 2xxx Series
Frequency          3392078523
Logical CPU Count  4
Summary
Elapsed Time:  0.761
CPU Time:      0.584
Event summary
Hardware Event Type               Hardware Event Count:Self  Hardware Event Sample Count:Self  Events Per Sample
CPU_CLK_UNHALTED.REF_TSC                         1982463296                              1011  2000003
ICACHE.MISSES                                        105801                                21  5000
Synchronization Context Switches                          0                                 0  0
Preemption Context Switches                              63                                63  0
Wait Time                                                 0                                 0  0
Inactive Time                                        867741                                63  0
Energy Core                                        12049264                               593  0
Energy GFX                                           162176                               593  0
Energy Pack                                        14334528                               593  0
amplxe: Executing actions 100 % done
(Virus scan in progress ...)
Peter_W_Intel
Parameter                 r016runsa
Result Size               1726725
CPU
Parameter          r016runsa
Logical CPU Count  4
Summary
Elapsed Time:  0.761
CPU Time:      0.584
Event summary
Wait Time                                                 0                                 0  0
Ayam
@Peter Wang thanks you so much. It has solved the issue.
However, can you please explain what is -knob enable-stack-collection=true. It is giving the readings of Energy Core and Energy DRAM. Can I say that these parameters are telling the energy reading for core and dram of a particular application.
Peter_W_Intel
I'm glad that the problem has been solved.
Energy counters are supported by some processors, they tell us about time wasted on core or on dram, you can see some inactive time in my result.
