Analyzers
5340 Discussions
Intel Advisor Crash while Summarizing Data for GPU Roofline Analysis
vtan
I have encountered error while running GPU Roofline analysis.
The application crashes after completed data collection and was in the process of summarizing the data.
AthiraM_Intel
Thank you for posting in Intel Analyzers Forum.
We tried to execute the roofline analysis with gpu profiling from our end using a sample and it worked successfully. Could you please check whether you are getting the same exception error while running samples in installed advisor folder.
Steps that worked for us:
Untar nqueens_advisor sample folder
$ cd advisor/2021.1/samples/en/C++/
$ tar -xvzf nqueens_Advisor.tgz
Build in release mode and run the 1_nqueens_serial sample
$ cd nqueens_Advisor
$ make 1_nqueens_serial
$ advisor --collect=roofline --profile-gpu -- ./1_nqueens_serial
Also , please share the sample reproducer code and the command you used to run the analysis for further debugging.
Thanks in advance,
Athira
AthiraM_Intel
Thanks in advance,
Athira
vtan
Hi Athira,
Thanks for your help and sorry for my late reply
I have tried your proposed solutions and it is working.
Vincent
AthiraM_Intel
Since you are able to run the sample, the issue might be related to your application.
Could you please share a sample reproducer code for further debugging from our end.
vtan
Hi Athira,
I was using your command line to run my targeted application and it worked.
Previously, I was running the collection using advisor-gui and it crashes halfway through.
FYI, the targeted application is the benchmark_app from OpenVINO 2021.1 with some models.
Vincent
AthiraM_Intel
Glad to know that your issue is resolved.
We are checking on the Advisor-gui issue.
DMITRY_T_Intel
I escalated this issue to development. I will let you know as soon as I get any information.
Thank you!
DMITRY_T_Intel
Hi Vincent,
Could you please tell us the GPU driver/runtime version and compiler version you used?
Thank you!
DMITRY_T_Intel
Hi Vincent,
Developers reported that this issue can't be reproduced with newer versions of Advisor (>= 608005). Please try the latest version and let me know if I can close his case.
Thank you!
DMITRY_T_Intel
Hi Vincent,
We will no longer follow this topic. If you run into this problem again or any new problem, just create a new topic and we will investigate it.
Thank you!
