Analyzers
5279 Discussions
Intel Inspector with distributed designs
AbhayBhatt
How to run the Intel Inspector GUI for distributed designs without using the command line with MPI ??
Ruslan_M_Intel
Could you please describe your application design in details? Is there any cross-node communication like MPI?
AbhayBhatt
Yes Actually we run through MPI for different values of 'n' but how we run this by GUI in Intel Inspector for Data race and Memory issues.
I run it by command line using mpirun ===> inspxe-cl -collect mi-2 -knob still-allocated-memory=true -knob stack-depth=16 -knob enable-on-demand-leak-detection=true -knob enable-dangling-pointer-check=true -knob enable-memory-growth-detection=true -offload-target=default -module-filter-mode=include -appdebug=off -result-dir mem9 -app-working-dir . -- $VMW_HOME/............
But when we launch the results in the GUI it is not shows the issue in summary.
Can you suggest the solution for this and also tell how to run distributed design in Intel Inspector GUI.
DiyaN_Intel
Good day to you.
We have not heard back from you.
Please provide the details mentioned above so that we can investigate the issue from our end.
Diya
DiyaN_Intel
Good day to you.
This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
Diya
