Hello guys,
Once I switch to HPC, Microarchitecture Exploration or Memory Access, I'm not able to run it (play button goes grey). Red text appears after description of selected profiling section (Screenshot_2.png).
Other case is when I'm running Hotspot profiling, Vtune Amplifier crashes. I managed to get part of the log before crashing (Screenshot_3.png). I would really appreciate your help.
OS: Windows Pro
Processor: Intel i7 7700 (3.6 GHz)
All the best,
Corbo Azer
Hi Azer,
Can you please provide the output of the following commands:
1) <VTune install dir>/bin64/amplxe-runss.exe -context-value-list
2) <VTune install dir>/bin64/sep.exe -version
As for the second issue - are you using "User-Mode Sampling" variant of Hotspots analysis? As result are you seeing profiling application crash or VTune crash? If latter, can you please share the content of VTune crash dialog?
Hello Vitaly,
Outputs, crash dialog and crash info are gonna be enlisted in attachment section.
About second issue - I'm using "User-Mode Sampling". When profiling is over and finalizing phase starts, then crash dialog (send or don't send report dialog emerges) comes up and VTune crashes.
Hi Azer,
Thanks for all the details. This looks similar to https://software.intel.com/en-us/forums/intel-vtune-amplifier/topic/814208 which we unfortunately unable to reproduce on our side. We're still attempting to find a reproducer in order to debug it directly. We're loosing a part of "sep -version" output while reading it within amplxe-runss, while there are no API errors and sep process finishes successfully. Also, in all the reported cases the same OS version was used: Microsoft Windows 10 Pro Build 18362.
As for the second issue leading to VTune crash - this is a known issue and crash should be fixed soon. Though the root cause might be similar to the first one.
Hi Vitaly,
I guess waiting for solution to pop up is the only thing left to do. Thank you for your time!
All the best,
Azer
Hi Azer,
Thanks for your patience.
Can you please help us to confirm both issues have the same root cause - please run the following command and provide its output:
<VTune install dir>/bin64/emon.exe -M
Thanks!
Thanks Azer for your support!
Yes, both issues are connected.
