Analyzers
5307 Discussions
Intel VTune not working with Xeon(R) Platinum 8488C
gerald2
Hi, When I try to run VTune on a recent AWS r7i instance with a Xeon(R) Platinum 8488C , I have the following message This analysis type is not applicable to the system because VTune Profiler cannot recognize the processor. If this is an old Intel processor, please refer to the minimum hardware requirements in the release note. If this is a new Intel processor, please check for an updated version of VTune Profiler. If this is an unreleased Intel processor, please contact Online Service Center for an NDA product package. Is there something to do, or should I wait for a new release? I'm using the last one available, 2024.1, from march 2024. Thanks
yuzhang3_intel
2024.1 should support the SPR platform. Have you been able to check if the VTune driver is ready? Please post your command line. Thanks.
gerald2
I didn't specify, I'm on Windows Server 2022.
Here is the command line for drivers
> "c:\Program Files (x86)\Intel\oneAPI\vtune\2024.1\bin64\amplxe-sepreg.exe" -s
Checking sepdrv5 driver path...OK
Checking sepdrv5 service...
Driver status: the sepdrv5 service is running
Checking sepdal driver path...OK
Checking sepdal service...
Driver status: the sepdal service is running
Checking socperf3 driver path...OK
Checking socperf3 service...
Driver status: the socperf3 service is running
Checking vtss driver path...OK
Checking vtss service...OK
It looks ok, but still I have the same error in VTune.
yuzhang3_intel
Please post the output of sep.exe -version (as administrator) and Windows Version & OS Build.
gerald2
"c:\Program Files (x86)\Intel\oneAPI\vtune\2024.1\bin64\sep.exe" -version doesn't provide any output.
For Windows version :
Edition Windows Server 2022 Datacenter
Version 21H2
Installed on ‎9/‎13/‎2023
OS build 20348.2402
gerald2
Any idea on what is wrong ?
yuzhang3_intel
It looks like there is something in environment prevents to detect CPU arch. I have escalated the issue to engineering team. We need some time to do investigations.
yuzhang3_intel
Could you share some information on your system:
1. Please check what antivirus is active on your system. It will be available at "Windows Security"->"Virus & threat protection"
You should see something like this - not necessarily CrowdStrike
2. Please share the output of the following command as well on all the systems:   systeminfo | findstr /B /C:"OS Name" /B /C:"OS Version"
gerald2
It looks like replying by email is not putting the answer here.  (And also, using Firefox here is not working, I cannot reply)
So here are the requested information
Here are the requested informations
1. Antivirus is Trend Micro Security
2. systeminfo | findstr /B /C:"OS Name" /B /C:"OS Version"
OS Name:                   Microsoft Windows Server 2022 Datacenter
OS Version:                10.0.20348 N/A Build 20348
3.Get-MpComputerStatus
AMEngineVersion                  : 0.0.0.0
AMProductVersion                 : 4.18.24040.4
AMRunningMode                    : Not running
AMServiceEnabled                 : False
AMServiceVersion                 : 0.0.0.0
AntispywareEnabled               : False
AntispywareSignatureAge          : 0
AntispywareSignatureLastUpdated  :
AntispywareSignatureVersion      :
AntivirusEnabled                 : False
AntivirusSignatureAge            : 65535
AntivirusSignatureLastUpdated    :
AntivirusSignatureVersion        :
BehaviorMonitorEnabled           : False
ComputerID                       : A4EB669A-9760-D83A-8A2E-610A0E210F77
ComputerState                    : 0
DefenderSignaturesOutOfDate      : False
DeviceControlDefaultEnforcement  : Unknown
DeviceControlPoliciesLastUpdated : 1/1/1601 1:00:00 AM
DeviceControlState               : Unknown
FullScanAge                      : 4294967295
FullScanEndTime                  :
FullScanOverdue                  : False
FullScanRequired                 : False
FullScanSignatureVersion         :
FullScanStartTime                :
InitializationProgress           : ServiceStartedSuccessfully
IoavProtectionEnabled            : False
IsTamperProtected                : False
IsVirtualMachine                 : True
LastFullScanSource               : 0
LastQuickScanSource              : 0
NISEnabled                       : False
NISEngineVersion                 : 0.0.0.0
NISSignatureAge                  : 65535
NISSignatureLastUpdated          :
NISSignatureVersion              :
OnAccessProtectionEnabled        : False
ProductStatus                    : 1
QuickScanAge                     : 4294967295
QuickScanEndTime                 :
QuickScanOverdue                 : False
QuickScanSignatureVersion        :
QuickScanStartTime               :
RealTimeProtectionEnabled        : False
RealTimeScanDirection            : 0
RebootRequired                   : False
SmartAppControlExpiration        :
SmartAppControlState             :
TamperProtectionSource           : Signatures
TDTCapable                       : N/A
TDTMode                          : N/A
TDTSiloType                      : N/A
TDTStatus                        : N/A
TDTTelemetry                     : N/A
TroubleShootingDailyMaxQuota     :
TroubleShootingDailyQuotaLeft    :
TroubleShootingEndTime           :
TroubleShootingExpirationLeft    :
TroubleShootingMode              :
TroubleShootingModeSource        :
TroubleShootingQuotaResetTime    :
TroubleShootingStartTime         :
PSComputerName                   :
gerald2
my answer is not going through.
gerald2
  1. systeminfo | findstr /B /C:"OS Name" /B /C:"OS Version"
  2. Get-MpComputerStatus
yuzhang3_intel
What does it mean here?
Could you post the screenshot of Antivirus?
gerald2
Here it is.
It is the same antivirus that is installed on another, older, AWS machine, with Windows Server 2012R2 ona r5.4xlarge, and Intel VTune is working find on this one.
yuzhang3_intel
Thanks for providing detailed information and a comparison. According to the engineering team update, the root cause has been found, and the bug will be fixed in a future release. Thanks.
gerald2
Thanks for the info. Any idea about an approximate timeline for this release?
yuzhang3_intel
2024.2.1 will fix the bug.
