Analyzers
4998 Discussions
Issue with vtune drivers being group permissioned
Rama__Fani
To facilitate usage of vtune among a couple of people, I have changed the group ownership of vtune drivers (/dev/{pax,socperf,sep5}) from vtune to some other group (mygroup). This was done via : insmod-sep -g mygroup when loading the driver
On RHEL 7.6 dev host, I'm having issue where if this `mygroup` is not the primary group of the user, then vtune-gui and vtune is unable to run properly and query the HW sampling drivers.
This does not seem to be an issue on RHEL 6.x.
straces seem inconclusive yet why vtune driver being group permissioned (perm 660 and ownership of root:mygroup) and user having group membership (primary_group, mygroup) does't work.
If I make the /dev/{pax,socperf,sep5} be root:primary_group, then it works.But making it root:mygroup fails on RHEL 7.x only
Any reason why? Something to do with sssd settings? Why is vtune not able to work with such a scenario? Any help please?
Adweidh_Intel
Dear Rama,
We are checking on this with concerned team, will get back to you at the earliest.
Vitaly_S_Intel
Hi Rama,
Is 'mygroup' listed in the 'id' command output run from the user?
In order to access VTune drivers by multiple people you should have added those to the 'vtune' group. Why didn't it work?
Rama__Fani
yes, `id` lists uid=<uid>(primary_group) gid=7000(vtune)
 `groups` lists `mygroup` as well as a group user belongs to. User's primary group is still `primary_group`
Users are part of `vtune` group and the drivers are group vtune writeable. .
Rama__Fani
I found the problem. We have the `vtune` group defined by a netgroup while there was a local definition of `vtune` group as well in /etc/group.
Removing the local /etc/group's vtune entry fixes the problem as it uses the one from netgroup and it all works.
Adweidh_Intel
Hi Rama,
It seems like your issue is fixed !! Shall we close this thread ?
