I am evaluating vtune and am getting the error "VM terminated. Exit code=1" when starting to use vtlec.
I am just trying the included sample gxsample2a, using the first use wizard, it crashes.
Brand new install on redhat enterprise linux 5. quad core amd64.
Eclipse 3.2.1 , Vtune 9.0.0, Java 1.5.0.10
Full error :
This problem has been posted in different guises over the last couple of years but there has been zero replies...
http://softwarecommunity.intel.com/isn/Community/en-US/forums/post/30223389.aspx
http://softwarecommunity.intel.com/isn/Community/en-US/forums/post/281323.aspx
http://softwarecommunity.intel.com/isn/Community/en-US/forums/post/30222992.aspx
http://software.intel.com/en-us/forums/showpost.php?p=20230
http://softwarecommunity.intel.com/isn/Community/en-US/forums/post/30236329.aspx
Thanks..
Configuration details :
*** Date: Wed Mar 19 17:12:55 CST 2008
*** Platform Details:
*** System properties:
eclipse.buildId=M20060921-0945
eclipse.commands=-os
linux
-ws
gtk
-arch
x86
-launcher
/opt/intel/eclipsepackage/3.2.1/eclipse/eclipse
-name
Eclipse
-showsplash
600
-exitdata
a290041
-product
com.intel.sdp.primary.product
-perspective
com.intel.vtune.shell.tuningPerspective
-vm
/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java
eclipse.ee.install.verify=false
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1205908859774
eclipse.vm=/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java
eclipse.vmargs=-Dosgi.splashLocation=/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/com.intel.sdp.primary_2.0.3/splash.bmp
-Dosgi.sharedConfiguration.area=/opt/intel/vtune/bin/../shared/eclipse/configuration
-jar
/opt/intel/eclipsepackage/3.2.1/eclipse/startup.jar
eof=eof
file.encoding=ANSI_X3.4-1968
file.encoding.pkg=sun.io
file.separator=/
java.awt.graphicsenv=sun.awt.X11GraphicsEnvironment
java.awt.printerjob=sun.print.PSPrinterJob
java.class.path=/opt/intel/eclipsepackage/3.2.1/eclipse/startup.jar
java.class.version=49.0
java.endorsed.dirs=/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/endorsed
java.ext.dirs=/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/ext
java.home=/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10
java.io.tmp dir=/tmp
java.library.path=/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/../lib/i386:/opt/intel/eclipsepackage/3.2.1/eclipse:/opt/intel/vtune/analyzer/bin:/opt/intel/vtune/shared/bin:/opt/sag/gcc-3.4/libem64t:/opt/sag/gcc-3.3/lib32:/opt/sag/gcc-3.3/lib32:/opt/sag/exx/v721/lib:/ps_rels/petrosys/Dev/linux_rhel5/ld_libs:/usr/local/lib:/opt/oracle/OraHome2/lib:/usr/lib:/ps_rels/petrosys/Dev/linux_rhel5/ld_libs:/usr/local/lib:/opt/oracle/OraHome2/lib:/usr/lib/firefox-1.5.0.12
java.runtime.name=Java 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_10-b03
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor=BEA Systems, Inc.
java.vendor.url=http://www.bea.com/
java.vendor.url.bug=http://support.bea.com
java.version=1.5.0_10
java.vm.info=compiled mode
java.vm.name=BEA JRockit
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=BEA Systems, Inc.
java.vm.vendor.url=http://www.bea.com/
java.vm.vendor.url.bug=http://support.bea.com
java.vm.version=R27.2.0-131-78843-1.5.0_10-20070320-1511-linux-ia32
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=OSGi/Minimum-1.0,OSGi/Minimum-1.1,JRE-1.1,J2SE-1.2,J2SE-1.3,J2SE-1.4,J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=Linux
org.osgi.framework.os.version=2.6.18-53.1.4.el5
org.osgi.framework.processor=i386
org.osgi.framework.system.packages=javax.accessibility,javax.activity,javax.crypto,javax.crypto.interfaces,javax.crypto.spec,javax.imageio,javax.imageio.event,javax.imageio.metadata,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax.imageio.spi,javax.imageio.stream,javax.management,javax.management.loading,javax.management.modelmbean,javax.management.monitor,javax.management.openmbean,javax.management.relation,javax.management.remote,javax.management.remote.rmi,javax.management.timer,javax.naming,javax.naming.directory,javax.naming.event,javax.naming.ldap,javax.naming.spi,javax.net,javax.net.ssl,javax.print,javax.print.attribute,javax.print.attribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA,javax.rmi.ssl,javax.security.auth,javax.security.auth.callback,javax.security.auth.kerberos,javax.security.auth.login,javax.security.auth.spi,javax.security.auth.x500,javax.security.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi.spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,javax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi,javax.swing,javax.swing.border,javax.swing.colorchooser,javax.swing.event,javax.swing.filechooser,javax.swing.plaf,javax.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.multi,javax.swing.plaf.synth,javax.swing.table,javax.swing.text,javax.swing.text.html,javax.swing.text.html.parser,javax.swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.transaction,javax.transaction.xa,javax.xml,javax.xml.datatype,javax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax.xml.transform.dom,javax.xml.transform.sax,javax.xml.transform.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss,org.omg.CORBA,org.omg.CORBA _2_3,org.omg.CORBA_2_3.portable,org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg.CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNaming,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNaming.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny,org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.DynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org.omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInterceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.omg.PortableServer,org.omg.PortableServer.CurrentPackage,org.omg.PortableServer.POAManagerPackage,org.omg.PortableServer.POAPackage,org.omg.PortableServer.portable,org.omg.PortableServer.ServantLocatorPackage,org.omg.SendingContext,org.omg.stub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.events,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax.helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.bundles=org.eclipse.equinox.common@2:start, org.eclipse.update.configurator@3:start, org.eclipse.core.runtime@start
osgi.bundlestore=/users/mark/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/bundles
osgi.configuration.area=file:/users/mark/.eclipse/org.eclipse.platform_3.2.0/configuration/
osgi.framework=file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.osgi_3.2.1.R32x_v20060919.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.2.1.R32x_v20060919
osgi.install.area=file:/opt/intel/eclipsepackage/3.2.1/eclipse/
osgi.instance.area=file:/users/mark/workspace/
osgi.instance.area.default=file:/users/mark/workspace/
osgi.logfile=/users/mark/workspace/.metadata/.log
osgi.manifest.cache=/users/mark/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.osgi/manifests
osgi.nl=en_US
osgi.os=linux
osgi.sharedConfiguration.area=file:/opt/intel/vtune/bin/../shared/eclipse/configuration/
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=/opt/intel/eclipsepackage/3.2.1/eclipse/plugins
osgi.ws=gtk
path.separator=:
sun.arch.data.model=32
sun.boot.class.path=/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit/jrockit1.5.0.jar:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit/managementapi.jar:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit/jmxmapi.jar:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386/jrockit/rmp.jar:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/rt.jar:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i18n.jar:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/sunrsasign.jar:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/jsse.jar:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/jce.jar:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/charsets.jar:/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/classes
sun.boot.library.path=/opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/lib/i386
sun.cpu.endian=little
sun.cpu.isalist=
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=A NSI_X3.4-1968
sun.management.compiler=BEA JRockit Optimizing Compiler
sun.os.patch.level=unknown
user.country=US
user.dir=/users/mark
user.home=/users/mark
user.language=en
user.name=mark
user.timezone=Australia/Adelaide
*** Features:
com.intel.vtune.analyzer (9.0.0) "VTune Performance Analyzer"
org.eclipse.cdt (3.1.2.200702150621) "Eclipse C/C++ Development Tools"
org.eclipse.platform (3.2.1.r321_v20060921-MGDh_08KUYM-Bvn) "Eclipse Platform"
org.eclipse.rcp (3.2.1.r321_v20060801-clWbqCmjexIWDqg) "Eclipse RCP"
*** Plug-in Registry:
com.ibm.icu (3.4.5) "International Components for Unicode for Java (ICU4J)" [Active]
com.intel.sdp.primary (2.0.3) "Intel Software Development Products" [Resolved]
com.intel.vtune.analyzer (9.0.0) "VTune Performance Analyzer" [Resolved]
com.intel.vtune.analyzer.callgraphconsumer (1.0.0) "VTune Performance Analyzer Callgraph Consumer" [Resolved]
com.intel.vtune.analyzer.cgutils (1.0.0) "VTune Performance Analyzer Utilities" [Resolved]
com.intel.vtune.analyzer.columnlayout (1.0.0) "VTune Performance Analyzer Column Layout" [Resolved]
com.intel.vtune.analyzer.help (1.0.0) "VTune Performance Analyzer Help" [Resolved]
com.intel.vtune.analyzer.optrepconsumer (1.0.1) "VTune Performance Analyzer Optimization Report Consumer" [Resolved]
com.intel.vtune.analyzer.ratios (1.0.0) "VTune Performance Analyzer Ratios" [Resolved]
com.intel.vtune.analyzer.samplingconsumer (1.0.1) "VTune Performance Analyzer Sampling Consumer" [Resolved]
com.intel.vtune.analyzer.svconsumer (1.0.1) "VTune Performance Analyzer Source View Consumer" [Resolved]
com.intel.vtune.analyzer.utils (1.0.0) "VTune Performance Analyzer Utilities" [Resolved]
com.intel.vtune.analyzer.wizards (1.0.0) "VTune Performance Analyzer Wizards" [Resolved]
com.intel.vtune.analyzer.wizards.callgraph (1.0.0) "VTune Performance Analyzer Wizards" [Resolved]
com.intel.vtune.analyzer.wizards.sampling (1.0.0) "VTune Performance Analyzer Wizards" [Resolved]
com.intel.vtune.FileSearch (1.0.0) "VTune File Search" [Resolved]
com.intel.vtune.idvclib (1.0.0) "VTune Performance Analyzer IDVC library" [Resolved]
com.intel.vtune.idvclibuni (1.0.0) "VTune Performance Analyzer IDVC Unicode library" [Resolved]
com.intel.vtune.pa.callgraph (1.0.0) "VTune Performance Analyzer Callgraph" [Resolved]
com.intel.vtune.pa.sampling (1.0.0) "VTune Performance Analyzer Sampling" [Resolved]
com.intel.vtune.pa.vtmh.dialogs (1.0.0) "VTune Performance Analyzer VTMH dialogs" [Resolved]
com.intel.vtune.reference.help (1.0.0) "VTune Performance Analyzer Reference" [Resolved]
com.intel.vtune.shell (1.0.0) "VTune Performance Environment" [Active]
com.intel.vtune.shell.activity (1.0.0) "VTune Performance Environment Activity" [Active]
com.intel.vtune.shell.help (1.0.0) "VTune Environment Help" [Resolved]
com.intel.vtune.shell.nointro (1.0.1) "VTune Performance Environment" [Resolved]
com.intel.vtune.shell.tuningbrowser (1.0.0) "VTune Performance Environment Tuning Browser" [Active]
com.intel.vtune.shell.tuningperspective (1.0.0) "VTune Performance Environment Tuning Perspective" [Active]
com.intel.vtune.vtmh.FileAssociation (1.0.0) "VTune Performance Analyzer VTMH File Association Preference Page" [Resolved]
com.intel.vtune.welcome (1.0.0) "VTune Perf ormance Analyzer Welcome, Start Panes and Welcome Page" [Active]
com.jcraft.jsch (0.1.28) "JSch" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.lucene (1.4.103.v20060601) "Apache Lucene" [Resolved]
org.eclipse.ant.core (3.1.100.v20060531) "Ant Build Tool Core" [Resolved]
org.eclipse.cdt (3.1.1.200609270800) "Eclipse C/C++ Development Tools" [Resolved]
org.eclipse.cdt.core (3.1.1.200609270800) "C/C++ Development Tools Core" [Active]
org.eclipse.cdt.core.linux (3.1.1.200609270800) "C/C++ Development Tools Core for Linux" [Resolved]
org.eclipse.cdt.core.linux.x86 (3.1.1.200609270800) "X86 Fragment" [Resolved]
org.eclipse.cdt.debug.core (3.1.1.200609270800) "C/C++ Development Tools Debug Model" [Resolved]
org.eclipse.cdt.debug.mi.core (3.1.1.200609270800) "C/C++ Development Tools GDB/MI CDI Debugger Core" [Resolved]
org.eclipse.cdt.debug.mi.ui (3.1.1.200609270800) "C/C++ Development Tools GDB/MI CDI Debugger UI" [Resolved]
org.eclipse.cdt.debug.ui (3.1.1.200609270800) "C/C++ Development Tools Debugger UI" [Resolved]
org.eclipse.cdt.doc.user (3.1.1.200609270800) "C/C++ Development User Guide" [Resolved]
org.eclipse.cdt.launch (3.1.1.200609270800) "C/C++ Development Tools Launching Support" [Resolved]
org.eclipse.cdt.make.core (3.1.1.200609270800) "C/C++ Standard make Build Core" [Active]
org.eclipse.cdt.make.ui (3.1.1.200609270800) "C/C++ Standard make Build UI" [Active]
org.eclipse.cdt.managedbuilder.core (3.1.1.200609270800) "C/C++ Managed Builder Core" [Active]
org.eclipse.cdt.managedbuilder.gnu.ui (3.1.1.200609270800) "GNU Managed Build Definitions" [Resolved]
org.eclipse.cdt.managedbuilder.ui (3.1.1.200609270800) "C/C++ Managed Builder UI" [Active]
org.eclipse.cdt.refactoring (3.1.1.200609270800) "C/C++ Refactoring" [Resolved]
org.eclipse.cdt.ui (3.1.1.200609270800) "C/C++ Development Tools UI" [Active]
org.eclipse.compare (3.2.1.M20060711) "Compare Support" [Resolved]
org.eclipse.core.boot (3.1.100.v20060603) "Core Boot" [Resolved]
org.eclipse.core.commands (3.2.0.I20060605-1400) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.0.v20060603) "Eclipse Content Mechanism" [Active]
org.eclipse.core.expressions (3.2.1.r321_v20060721) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.2.1.r321_v20060721) "File Buffers" [Active]
org.eclipse.core.filesystem (1.0.0.v20060603) "Core File Systems" [Resolved]
org.eclipse.core.filesystem.linux.x86 (1.0.0.v20060603) "Core File System for Linux" [Resolved]
org.eclipse.core.jobs (3.2.0.v20060603) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.resources (3.2.1.R32x_v20060914) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.2.0.v20060603) "Core Resource Management Compatibility Fragment" [Resolved]
org.eclipse.core.runtime (3.2.0.v20060603) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.100.v20060603) "Core Runtime Plug-in Compatibility" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.0.v20060601) "Authorization Compatibility Plug-in" [Active]
org.eclipse.core.runtime.compatibility.registry (3.2.1.R32x_v20060907) "Eclipse Registry Compatibility Fragment" [Resolved]
org.eclipse.core.variables (3.1.100.v20060605) "Core Variables" [Resolved]
org.eclipse.debug.core (3.2.1.v20060823) "Debug Core" [Active]
org.eclipse.debug.ui (3.2.1.v20060823) "Debug UI" [Active]
org.eclipse.equinox.co mmon (3.2.0.v20060603) "Common Eclipse Runtime" [Active]
org.eclipse.equinox.preferences (3.2.1.R32x_v20060717) "Eclipse Preferences Mechanism" [Active]
org.eclipse.equinox.registry (3.2.1.R32x_v20060814) "Extension Registry Support" [Active]
org.eclipse.help (3.2.1.R321_v20060920) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.100.v20060602) "Help Application Server" [Resolved]
org.eclipse.help.base (3.2.1.R321_v20060822) "Help System Base" [Active]
org.eclipse.help.ui (3.2.0.v20060602) "Help System UI" [Active]
org.eclipse.help.webapp (3.2.1.R321_v20060803) "Help System Webapp" [Resolved]
org.eclipse.jface (3.2.1.M20060908-1000) "JFace" [Resolved]
org.eclipse.jface.databinding (1.0.0.I20060605-1400) "JFace Data Binding" [Resolved]
org.eclipse.jface.text (3.2.1.r321_v20060810) "JFace Text" [Resolved]
org.eclipse.ltk.core.refactoring (3.2.1.r321_v20060823) "Refactoring Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.2.1.r321_v20060726) "Refactoring UI" [Resolved]
org.eclipse.osgi.services (3.1.100.v20060601) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.100.v20060601) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.platform (3.2.0.v20060601) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.user (3.2.1.R32x_v200608101155) "Eclipse Workbench User Guide" [Resolved]
org.eclipse.rcp (3.2.0.v20060605) "Eclipse RCP" [Resolved]
org.eclipse.search (3.2.1.r321_v20060726) "Search Support" [Active]
org.eclipse.swt (3.2.1.v3235e) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.gtk.linux.x86 (3.2.1.v3235) "Standard Widget Toolkit for GTK 2.0" [Resolved]
org.eclipse.team.core (3.2.1.M20060711) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.2.1.M200608161750) "CVS Team Provider Core" [Resolved]
org.eclipse.team.cvs.ssh (3.2.0.I200606011710) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.2.0.I200606051140) "CVS SSH2" [Resolved]
org.eclipse.team.cvs.ui (3.2.1.M20060831) "CVS Team Provider UI" [Resolved]
org.eclipse.team.ui (3.2.1.M200608151725) "Team Support UI" [Resolved]
org.eclipse.text (3.2.0.v20060605-1400) "Text" [Resolved]
org.eclipse.tomcat (4.1.130.v20060601) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.2.1.M20060913-0800) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.2.0.v20060602) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.2.1.R321_v20060720) "Cheat Sheets" [Active]
org.eclipse.ui.console (3.1.100.v20060605) "Console" [Active]
org.eclipse.ui.editors (3.2.1.r321_v20060721) "Default Text Editor" [Active]
org.eclipse.ui.externaltools (3.1.101.r321_v20060802) "External Tools" [Active]
org.eclipse.ui.forms (3.2.0.v20060602) "Eclipse Forms" [Active]
org.eclipse.ui.ide (3.2.1.M20060915-1030) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.2.1.R321_v20060810) "Welcome Framework" [Active]
org.eclipse.ui.intro.universal (3.2.1.R321_v20060905) "Universal Welcome" [Resolved]
org.eclipse.ui.navigator (3.2.1.M20060913-0800) "Common Navigator View" [Resolved]
org.eclipse.ui.navigator.resources (3.2.1.M20060906-0800b) "Navigator Workbench Components" [Resolved]
org.eclipse.ui.presentations.r21 (3.2.0.I20060605-1400) "R21 Presentation Plug-in" [Resolved]
org.eclipse.ui.views (3.2.1.M20060906-0800) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.2.1.M20060830-0800) "Tabbed Properties View" [Resolved]
org.eclipse.ui.workbench (3.2.1.M200 60906-0800) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.2.0.I20060605-1400) "Workbench Compatibility" [Resolved]
org.eclipse.ui.workbench.texteditor (3.2.0.v20060605-1400) "Text Editor Framework" [Active]
org.eclipse.update.configurator (3.2.1.v20092006) "Install/Update Configurator" [Active]
org.eclipse.update.core (3.2.1.v20092006) "Install/Update Core" [Active]
org.eclipse.update.core.linux (3.2.0.v20060605) "Install/Update Core for Linux" [Resolved]
org.eclipse.update.scheduler (3.2.1.v20092006) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.2.1.v20092006) "Install/Update UI" [Resolved]
system.bundle (3.2.1.R32x_v20060919) "OSGi System Bundle" [Active]
*** User Preferences:
#Wed Mar 19 17:12:55 CST 2008
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Monospace|10|0|GTK|1|;
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterprofiles.version=10
@org.eclipse.ui=3.2.1.M20060913-0800
/instance/org.eclipse.ui.ide/platformState=1205712090421
/instance/org.eclipse.cdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.ui.browser/browsers=
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_DIALOG=false
/instance/org.eclipse.cdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder.resourceCopyExclusionFilter=*.launch
@org.eclipse.ui.browser=3.2.0.v20060602
/instance/org.eclipse.ui.ide/tipsAndTricks=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.width=
/instance/org.eclipse.jdt.ui/proposalOrderMigrated=true
/instance/org.eclipse.cdt.debug.core/org.eclipse.cdt.debug.core.cDebug.common_source_containers=
@org.eclipse.core.resources=3.2.1.R32x_v20060914
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
@org.eclipse.ui.ide=3.2.1.M20060915-1030
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL=2
@org.eclipse.cdt.ui=3.1.1.200609270800
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=/users/mark/workspace,/net/psadl1/users/mark/workspace
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocations.migrated=true
@org.eclipse.cdt.debug.core=3.1.1.200609270800
file_export_version=3.0
*** Current Install Configuration:
Install configuration:
Last changed on Mar 17, 2008
Location: file:/users/mark/.eclipse/org.eclipse.platform_3.2.0/configuration/org.eclipse.update/platform.xml
Configured sites:
platform:/base/
file:/opt/intel/vtune/analyzer/eclipse/
file:/opt/intel/vtune/shared/eclipse/
Configured features:
ID: org.eclipse.platform, Version: 3.2.1.r321_v20060921-MGDh_08KUYM-Bvn
ID: org.eclipse.rcp, Version: 3.2.1.r321_v20060801-clWbqCmjexIWDqg
ID: org.eclipse. platform.source, Version: 3.2.1.r321_v20060921-MGDh_08KUYM-Bvn
ID: org.eclipse.jdt, Version: 3.2.1.r321_v20060905-R4CM1Znkvre9wC-
ID: org.eclipse.jdt.source, Version: 3.2.1.r321_v20060905-R4CM1Znkvre9wC-
ID: org.eclipse.pde, Version: 3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG
ID: org.eclipse.pde.source, Version: 3.2.1.r321_v20060823-6vYLLdQ3Nk8DrFG
ID: org.eclipse.rcp.source, Version: 3.2.1.r321_v20060801-clWbqCmjexIWDqg
ID: org.eclipse.cdt, Version: 3.1.2.200702150621
ID: com.intel.vtune.pa.sourceview, Version: 1.0.0
ID: com.intel.vtune.pa.samplingfeature, Version: 1.0.0
ID: com.intel.vtune.analyzer, Version: 9.0.0
ID: com.intel.vtune.pa.callgraphfeature, Version: 1.0.0
ID: com.intel.vtune.shell-feature, Version: 1.0.0
Configured plug-ins:
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.filesystem.linux.x86_1.0.0.v20060603.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.console_3.1.100.v20060605.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.equinox.preferences_3.2.1.R32x_v20060717.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.swt_3.2.1.v3235e.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.runtime.compatibility_3.1.100.v20060603.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.apache.lucene_1.4.103.v20060601/
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.jface.text_3.2.1.r321_v20060810.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.resources.compatibility_3.2.0.v20060603.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.osgi.util_3.1.100.v20060601.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/com.intel.sdp.primary_2.0.3/
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.runtime.compatibility.auth_3.2.0.v20060601.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.update.core.linux_3.2.0.v20060605.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.core.linux.x86_3.1.1.200609270800/
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.jobs_3.2.0.v20060603.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.team.cvs.ssh_3.2.0.I200606011710.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.debug.mi.core_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.core.linux_3.1.1.200609270800/
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.browser_3.2.0.v20060602.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.navigator.resources_3.2.1.M20060906-0800b.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.views.properties.tabbed_3.2.1.M20060830-0800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.team.cvs.ssh2_3.2.0.I200606051140.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.debug.core_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/ eclipse/plugins/org.eclipse.tomcat_4.1.130.v20060601/
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.help_3.2.1.R321_v20060920.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.managedbuilder.gnu.ui_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.team.cvs.ui_3.2.1.M20060831.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.externaltools_3.1.101.r321_v20060802.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.jface_3.2.1.M20060908-1000.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.managedbuilder.ui_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.launch_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.workbench.compatibility_3.2.0.I20060605-1400/
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.contenttype_3.2.0.v20060603.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.filesystem_1.0.0.v20060603.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.navigator_3.2.1.M20060913-0800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.workbench.texteditor_3.2.0.v20060605-1400.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.presentations.r21_3.2.0.I20060605-1400.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.apache.ant_1.6.5/
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.boot_3.1.100.v20060603.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.filebuffers_3.2.1.r321_v20060721.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.commands_3.2.0.I20060605-1400.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.debug.ui_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.search_3.2.1.r321_v20060726.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.core_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.doc.user_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.help.webapp_3.2.1.R321_v20060803/
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.update.core_3.2.1.v20092006.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.workbench_3.2.1.M20060906-0800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.equinox.registry_3.2.1.R32x_v20060814.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.team.core_3.2.1.M20060711.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.variables_3.1.100.v20060605.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.help.ui_3.2.0.v20060602.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.editors_3.2.1.r321_v20060721.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.refactoring_3.1.1.200609270800. jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.ide_3.2.1.M20060915-1030.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.update.scheduler_3.2.1.v20092006.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/com.ibm.icu_3.4.5.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.team.cvs.core_3.2.1.M200608161750.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.help.base_3.2.1.R321_v20060822.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.team.ui_3.2.1.M200608151725.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.jface.databinding_1.0.0.I20060605-1400.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.text_3.2.0.v20060605-1400.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/com.jcraft.jsch_0.1.28.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ant.core_3.1.100.v20060531.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ltk.ui.refactoring_3.2.1.r321_v20060726.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.make.ui_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.swt.gtk.linux.x86_3.2.1.v3235.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.compare_3.2.1.M20060711.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.equinox.common_3.2.0.v20060603.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.intro_3.2.1.R321_v20060810.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.managedbuilder.core_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.intro.universal_3.2.1.R321_v20060905/
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.debug.core_3.2.1.v20060823.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.forms_3.2.0.v20060602.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ltk.core.refactoring_3.2.1.r321_v20060823.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui_3.2.1.M20060913-0800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.platform_3.2.0.v20060601/
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.expressions_3.2.1.r321_v20060721.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.views_3.2.1.M20060906-0800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.platform.doc.user_3.2.1.R32x_v200608101155.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.runtime_3.2.0.v20060603.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.ui.cheatsheets_3.2.1.R321_v20060720.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.debug.mi.ui_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.help.appserver_3.1.100.v20060602.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.resources_3.2.1.R32x_v20060914.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.osgi.services_3.1.100.v 20060601.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.update.configurator_3.2.1.v20092006.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.ui_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.update.ui_3.2.1.v20092006.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.cdt.make.core_3.1.1.200609270800.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.rcp_3.2.0.v20060605.jar
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.core.runtime.compatibility.registry_3.2.1.R32x_v20060907/
file:/opt/intel/eclipsepackage/3.2.1/eclipse/plugins/org.eclipse.debug.ui_3.2.1.v20060823.jar
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer_9.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.vtmh.FileAssociation_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.svconsumer_1.0.1/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.wizards.callgraph_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.utils_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.samplingconsumer_1.0.1/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.reference.help_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.pa.vtmh.dialogs_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.columnlayout_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.callgraphconsumer_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.pa.callgraph_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.welcome_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.wizards.sampling_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.cgutils_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.wizards_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.help_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.pa.sampling_1.0.0/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.optrepconsumer_1.0.1/
file:/opt/intel/vtune/analyzer/eclipse/plugins/com.intel.vtune.analyzer.ratios/
file:/opt/intel/vtune/shared/eclipse/plugins/com.intel.vtune.idvclibuni_1.0.0/
file:/opt/intel/vtune/shared/eclipse/plugins/com.intel.vtune.shell_1.0.0/
file:/opt/intel/vtune/shared/eclipse/plugins/com.intel.vtune.shell.help_1.0.0/
file:/opt/intel/vtune/shared/eclipse/plugins/com.intel.vtune.shell.activity_1.0.0/
file:/opt/intel/vtune/shared/eclipse/plugins/com.intel.vtune.shell.tuningperspective_1.0.0/
file:/opt/intel/vtune/shared/eclipse/plugins/com.intel.vtune.idvclib_1.0.0/
file:/opt/intel/vtune/shared/eclipse/plugins/com.intel.vtune.shell.tuningbrowser_1.0.0/
file:/opt/intel/vtune/shared/eclipse/plugins/com.intel.vtune.shell.nointro_1.0.1/
file:/opt/intel/vtune/shared/eclipse/plugins/com.intel.vtune.FileSearch/
Full error :
JVM terminated. Exit code=1
-jar /opt/intel/eclipsepackage/3.2.1/eclipse/startup.jar
-os linux
-ws gtk
-arch x86
-launcher /opt/intel/eclipsepackage/3.2.1/eclipse/eclipse
-name Eclipse
-showsplash 600
-exitdata a26804a
-product com.intel.sdp.primary.product
-perspective com.intel.vtune.shell.tuningPerspective
-vm /opt/intel/eclipsepackage/3.2.1/jrockit-R27.2.0-jre1.5.0_10/bin/java
-vmargs
Thanks..
linux
-ws
gtk
-arch
x86
-launcher
-name
Eclipse
-showsplash
600
-exitdata
a290041
-product
-perspective
-vm
-jar
eof=eof
file.separator=/
line.separator=
os.arch=i386
os.name=Linux
osgi.arch=x86
osgi.nl=en_US
osgi.os=linux
osgi.ws=gtk
path.separator=:
sun.cpu.isalist=
user.country=US
user.language=en
user.name=mark
*** Features:
Configured sites:
platform:/base/
Topic Options
