Community
cancel
Showing results for
Search instead for
Did you mean:
prem_k_
Looking for right Vtune lunix version for RHEL 5.4
Currently some our server are  running Red Hat Enterprise Linux Server release 5.4 (Tikanga).
can someone please  let  which  vtune  version support RHEL 5.4 . how to  download  it
TimP
Black Belt
Referring to https://software.intel.com/sites/default/files/managed/d8/4a/release_notes_amplifier_linux.pdf
you will see that rh 5.4 was supported thru xe2016.
I'm not certain when support for 32-bit rh5 was dropped.
As with the instructions for downloading older compilers, registrationcenter.intel.com will allow downloading of any versions of Intel software tools for which you have a license.  A license works with all versions issued before expiration of the license.
prem_k_
downloaded  the 2017 version . getting  below  failure
Step 6 of 7 | Installation
Each component will be installed individually. If you cancel the installation,
some components might remain on your system. This installation may take several
minutes, depending on your system and the options you selected.
Installing Command line interface component... failed
Failed to install component
intel-vtune-amplifier-xe-2017-cli-17.2-499904.i486.rpm
a. Abort
i. Ignore
Please type a selection or press "Enter" to accept default choice :
prem_k_
upload the error file for more context
TimP
Black Belt
Vtune 2017 has dropped support of 32bit os as well as rh 5.
prem_k_
Deployed 2013  now  . now   held at the error below . let know how we can overcome this
TimP
Black Belt
You and I both would need to reread those docs.  Evidently, it has been some years since I tried this, and not on a 32-bit system, so I'm not much further ahead than you, but I remember them as reasonably self-explanatory.  If your running kernel didn't match one provided with the installer, it's quite likely you need to simply run the build and install scripts.  If you run as superuser, you don't need to set up the groups, but obviously that's not a long term solution.
prem_k_
i attempted to  build and deploy the driver .  getting ERROR: UNSUPPORTED platform
ppitchaimuthu@stage2lp72 tools]$
[ppitchaimuthu@stage2lp72 tools]$ sudo -s
[root@stage2lp72 tools]# ./insmod-sep3
ls: ./sep3_10-x32_64-*2.6.18*.ko: No such file or directory
Could not update the driver. Please make sure update_sep_version.pl is in the . directory
Warning: sep3_10 driver "sep3_10-x32_64-2.6.18-348.4.1.el5smp.ko"
was not found in directory "." !
This means you may need to build sep3_10 driver from the provided
driver sources.  Please see the driver README for instructions.
[root@stage2lp72 tools]# ./integ_machine_check.sh
[root@stage2lp72 tools]# uname -a
Linux stage2lp72 2.6.18-348.4.1.el5 #1 SMP Fri Mar 22 05:41:51 EDT 2013 x86_64 x86_64 x86_64 GNU/Linux
TimP
Black Belt
Can you follow the instruction to use the README for instructions on building a driver?
