Analyzers
5287 Discussions
Memory growth detection with command-line?
Victor_B_2
There is a "enable-memory-growth-detection" knob in inspxe-cl, how is it possible to use it within the command line?
Peter_W_Intel
Please see this article - I'm sorry there are some Chinese characters, but you can read example code and follow steps. It should work.
Victor_B_2
Thanks!
I've tried that and it seems like memory-growth-start doesn't work correctly (I'm using 2013-u3 because of the interactive console bug in recent versions): it lists all allocated memory from the process start as "Memory growth" until transaction end, instead of the difference between transaction start and end.
Peter_W_Intel
Don't know why it didn't work on your side. Have you tested my test case in article?
I just verified, it worked. My version -
# inspxe-cl -version
Intel(R) Inspector XE 2013 Update 6 (build 283349) Command Line tool
Copyright (C) 2009-2013 Intel Corporation. All rights reserved.
Please see my attaching screen-shot.
