Analyzers
5214 Discussions
No gpu info was collected with advisor -collect roofline
nahso
Here is a program of matrix-matrix multiplication. I can not collect any gpu info with the command:
advisor --collect=roofline --profile-gpu --project-dir=./advi --search-dir src:p=./advi -- ./a.out
Here is the result:
I want to collect the GFLOPS of gemm_micro_kernel, can any one help me?
Versions:
Intel(R) Advisor 2022.1 (build 613050) Command Line Tool
Ubuntu 20.04
Intel(R) oneAPI DPC++/C++ Compiler 2022.1.0 (2022.1.0.20220316)
GPU: ATS-P
How to compile:
dpcpp dense-advisor.cpp
Code:
#include <iostream>
#include <string>
#include <cstring>
#include <CL/sycl.hpp>
#include <chrono>
#include <random>
#define bm 16
#define bn 16
#define bk 16
#define upper_divide(a, b) ((((a) - 1) / (b) + 1) * (b))
using kernel_type = float;
sycl::queue q(sycl::gpu_selector{});
constexpr size_t m = 100, n = 200, k = 300;
constexpr size_t pad_m = upper_divide(m, bm*4), pad_n = upper_divide(n, bn), pad_k = upper_divide(k, bk);
void demo_data(kernel_type* amat, kernel_type* bmat, kernel_type* result);
void gemm_micro_kernel(kernel_type* A, kernel_type* B, kernel_type* C); // kernel5 + kernel3
int main(int argc, char** argv)
    kernel_type* amat = new kernel_type[m*k];
    kernel_type* bmat = new kernel_type[k*n];
    kernel_type* result = new kernel_type[m*n];
    demo_data(amat, bmat, result);
    // init
    kernel_type* amat_dev = sycl::malloc_device<kernel_type>(m*k, q);
    kernel_type* bmat_dev = sycl::malloc_device<kernel_type>(k*n, q);
    q.memcpy(amat_dev, amat, m*k * sizeof(kernel_type)).wait();
    q.memcpy(bmat_dev, bmat, k*n * sizeof(kernel_type)).wait();
    kernel_type* A = sycl::malloc_shared<kernel_type>(pad_m*pad_k, q);
    kernel_type* B = sycl::malloc_shared<kernel_type>(pad_k*pad_n, q);
    q.memset(A, 0, sizeof(kernel_type) * pad_m * pad_k).wait();
    q.memset(B, 0, sizeof(kernel_type) * pad_k * pad_n).wait();
    q.parallel_for(sycl::range(m, k), [=](sycl::id<2> it) {
        A[it[0] * pad_k + it[1]] = amat_dev[it[0] * k + it[1]];
    }).wait();
    q.parallel_for(sycl::range(k, n), [=](sycl::id<2> it) {
        B[it[0] * pad_n + it[1]] = bmat_dev[it[0] * n + it[1]];
    }).wait();
    auto* output = sycl::malloc_shared<kernel_type>(pad_m*pad_n, q);
    auto* output_refer = sycl::malloc_shared<kernel_type>(pad_m*pad_n, q);
    std::cout << "init done.\n";
    std::chrono::steady_clock::time_point t1 = std::chrono::steady_clock::now();
    gemm_micro_kernel(A, B, output);
    std::chrono::steady_clock::time_point t2 = std::chrono::steady_clock::now();
    auto us = std::chrono::duration_cast<std::chrono::microseconds>(t2 - t1).count();
    double ms = (double)us / 1000;
    std::cout << "kernel time: " << us << " us. i.e " << ms << "ms.\n";
    return 0;
    size_t lda = pad_m, ldb = pad_k, ldc = pad_m;
    sycl::range<2> global_range(pad_m/4, pad_n), local_range(bm, bn);
    q.submit([&](sycl::handler& h) {
        sycl::accessor<kernel_type, 1, sycl::access::mode::read_write, sycl::access::target::local> sa(sycl::range(bm*4 * bk), h);
        sycl::accessor<kernel_type, 1, sycl::access::mode::read_write, sycl::access::target::local> sb(sycl::range(bk * bn), h);
        h.parallel_for(sycl::nd_range<2>(global_range, local_range), [=](sycl::nd_item<2> it) [[intel::reqd_sub_group_size(16)]] {
            size_t i = it.get_global_id(0) * 4;
            size_t j = it.get_global_id(1);
            size_t ti = it.get_local_id(0);
            size_t tj = it.get_local_id(1);
            kernel_type sum_arr[4] = {0, 0, 0, 0};
            kernel_type b00;
            for (size_t ki = 0; ki < pad_k; ki += bk) {
                sa[(ti*4)*bk   + tj] = A[i*pad_k     + ki + tj];
                sa[(ti*4+1)*bk + tj] = A[(i+1)*pad_k + ki + tj];
                sa[(ti*4+2)*bk + tj] = A[(i+2)*pad_k + ki + tj];
                sa[(ti*4+3)*bk + tj] = A[(i+3)*pad_k + ki + tj];
                sb[tj*bn + ti  ] = B[(ki+ti)*pad_n   + j];
                it.barrier(sycl::access::fence_space::local_space);
#pragma unroll
                for (size_t inner_k_count = 0; inner_k_count < bk; inner_k_count++) {
                    b00 = sb[tj * bn + inner_k_count];
                    sum_arr[0] += sa[(ti*4) * bk + inner_k_count] * b00;
                    sum_arr[1] += sa[(ti*4+1) * bk + inner_k_count] * b00;
                    sum_arr[2] += sa[(ti*4+2) * bk + inner_k_count] * b00;
                    sum_arr[3] += sa[(ti*4+3) * bk + inner_k_count] * b00;
            C[i * pad_n + j] = sum_arr[0];
            C[(i+1) * pad_n + j] = sum_arr[1];
            C[(i+2) * pad_n + j] = sum_arr[2];
            C[(i+3) * pad_n + j] = sum_arr[3];
    q.wait();
    size_t id = 0;
    std::default_random_engine e(time(0));
    std::uniform_real_distribution<double> u(-100, 100);
    for (size_t i = 0; i < m*k; ++i) amat[i] = u(e);
    for (size_t i = 0; i < k*n; ++i) bmat[i] = u(e);
Rahila_T_Intel
We are able to get GPU Roofline chart using your workload. However, we have increased workload size to make it x100 time bigger.
Please find the attached report containing GPU info .
Hope this addresses your queries. If so, kindly click the “Accept as Solution” button to indicate that your issue is resolved. This will also help others with a similar issue.
Please let us know if we can close the case.
Rahila_T_Intel
Thank you for posting in Intel communities.
Sorry for the delay. We are able to reproduce the issue from our end and we could see that the reason behind the low execution time is your code. Since your code takes very small time to execute it is not get captured.
If this clarify your query, make sure to accept this as a solution. This would help others with similar issues.
nahso
But advisor works in this kernel with same size of inputs
        h.parallel_for(sycl::nd_range<2>(global_range, local_range), [=](sycl::nd_item<2> it) {
            size_t i = it.get_global_id(0);
            kernel_type sum = 0;
            for (size_t ki = 0; ki < k; ++ki) {
                sum += A[i * pad_k + ki] * B[ki * pad_n + j];
            C[i * pad_n + j] = sum;
    }).wait();
 Actually, even I input a huge sample to the previous kernel, advisor still can not capture any flops.
Rahila_T_Intel
Could you please try to run the same analysis with the matrix_mul_dpcpp.cpp which is available in the below GitHub link.
https://github.com/oneapi-src/oneAPI-samples/tree/2022.3/DirectProgramming/DPC%2B%2B/DenseLinearAlgebra/matrix_mul/src
Please share the screenshot to verify whether gpu info is collected or not.
nahso
here is the `summary` tab
but I can see the result in `GPU Roofline Regions` tab with this options checked
BTW, here is the CLI output
Rahila_T_Intel
nahso
Rahila_T_Intel
Thanks for accepting our solution. Glad to know that your issue is resolved.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
