I have been install Vtune 9.1 with license server, but it does not work so I removed it.
Then, I downloaded and installed an evaluation version of Vtune 9.1, C++ and fortran compiler.
I can install them successfully. I can compile the program by C++ anc fortran compiler.
But, I can run Vtune analyzer. It shows message "Not able to connect to license server for Intel Vtune"
How can I fix it?
Did you copy the VTune evaluation license into /opt/intel/licenses? If you have a license for the flexlm server, but you don't have a connection to the server, you may have to remove that license.
