Analyzers
4999 Discussions
Not even close
namsaray
I downloaded a trial version, and it sucks.
C++, 64 bit.
I commented out a delete statement as the simple test, and
VS 2010 compiler points to memory leaks, and this expensive tool is way off - points me to some DLLs and
handles that are actually properly disposed of.
I did not change any parameters, just ran "Memory error analysis/detect leaks".
What gives?
Am I doing something wrong?
Please advise,
Thank you
Holly_W_Intel
Would it be possible for you to attach the results or give a code sample so thatwe could get a better idea of why you might be seeing this?
Mark_D_Intel
One possible issue is IXE only reports unreachable leaks. If there exists some pointer to the allocated memory at program exit, it will not be reported.
You could also try a different analysis type ("Detect Memory Problems" or "Locate Memory Problems"). These use a slightly different instrumentation approach than "Detect Leaks", and may give different results.
SergeyKostrov
Valued Contributor II
One possible issue is IXE only reports unreachable leaks.If there exists some pointer to the allocated memory at program exit, it will not be reported...
Mark,
I didn't hear anything about Unreachable Leaks. Could you provide aC or C++ test case, please?
Sergey
Mark_D_Intel
#include
#include
int *make_unreachable_leak()
// Will be reported by Inspector XE
int *tmp = (int *)malloc(sizeof(int));
return NULL;
int *make_reachable_leak()
// Still accessible through global pointer
// Will not be reported by Inspector XE
return tmp;
int *ptr;
int main(int argc, char **argv)
make_unreachable_leak();
ptr = make_reachable_leak();
return 0;
SergeyKostrov
Thank you, Mark!
Sergey
SergeyKostrov
Hi Mark,
I'll try to do a follow up onyour Test-Case tomorrow.
Sergey
SergeyKostrov
return tmp;
Mark,
I think it has to be fixed because this is wrong. In both cases memory is allocated from a heap and
a Win32 API function 'HeapAlloc' is used. I will provide two reports from built-in Memory Leaks detection systems
implemented by Microsoft and for the ScaLib project.
Sergey
SergeyKostrov
Here are Test-Cases:
[cpp]... RTint *g_iPointer = RTnull; RTint * MakeUnreachableLeak( RTvoid ) // Will be reported by Inspector XE { // RTint *iTmp = ( RTint * )malloc( sizeof( RTint ) ); // RTint *iTmp = ( RTint * )new RTint( 777 ); RTint *iTmp = ( RTint * )CrtNew RTint( 777 ); return ( RTint * )RTnull; } // Accessible through global pointer RTint * MakeReachableLeak( RTvoid ) // Will not be reported by Inspector XE { // RTint *iTmp = ( RTint * )malloc( sizeof( RTint ) ); // RTint *iTmp = ( RTint * )new RTint( 777 ); RTint *iTmp = ( RTint * )CrtNew RTint( 777 ); return ( RTint * )iTmp; } ... ... // Sub-Test 2.1 - Microsoft MLD { RTbool bOk = RTfalse; _CrtSetDbgFlag( _CRTDBG_ALLOC_MEM_DF | _CRTDBG_LEAK_CHECK_DF ); _CrtSetReportMode( _CRT_ERROR, _CRTDBG_MODE_DEBUG | _CRTDBG_MODE_WNDW ); MakeUnreachableLeak(); g_iPointer = MakeReachableLeak(); _CrtDumpMemoryLeaks(); } ... or ... // Sub-Test 2.2 - ScaLib MLD { RTbool bOk = RTfalse; MakeUnreachableLeak(); g_iPointer = MakeReachableLeak(); bOk = MemoryTracerData(); bOk = MemoryTracerIntegrity(); } ... [/cpp]
SergeyKostrov
Note: MLD stands for Memory Leaks Detection.
Here are results:
>> Microsoft MLD - CRT-function 'malloc' is used <<
Detected memory leaks!
Dumping objects ->
{76} normal block at 0x02124470, 4 bytes long.
Data: < > CD CD CD CD
{75} normal block at 0x02124430, 4 bytes long.
Object dump complete.
>> Microsoft MLD - C++ operator 'new' is used <<
Dumping objects ->
Data: < > 09 03 00 00
>> ScaLib MLD - C++ operator 'CrtNew' is used ( the same as 'new' ) <<
* Memory Block: 0 *
..\common\prttests.cpp(6527)
Memory Block State: 1 - Allocated by CrtNew
* Memory Block: 1 *
..\common\prttests.cpp(6534)
Memory Blocks Allocated : 2
Memory Blocks Released : 0
Memory Blocks NOT Released: 2
Memory Tracer Integrity Verified - Memory Leaks Detected
SergeyKostrov
Please take a look attwo comments.
Quoting Sergey Kostrov
Dumping objects ->
[SergeyK] Not initialized by 'malloc'
Dumping objects ->
[SergeyK] Initialized with a value 777 ( 0x00000309) by 'new'
Sergey
SergeyKostrov
Are there any updates on the problem?
Sergey
Bernard
I would suggest to use windbg for memory leaks detection, because of large set of commands and very good extensions for example !heap command can you save a lot of pain caused by manually walk the heap.
Here is good tutorial for the memory leaks detection with the help of windbg : http://www.codeproject.com/Articles/31382/Memory-Leak-Detection-Using-Windbg
SergeyKostrov
Quoting iliyapolak
can you save a lot of pain caused by manually walk the heap...
In 2007 I worked for an image processingproject and it had more than 30,000 memory leaks...
Some developers / users on the forumare dealing with even more memory leaks, something like 100,000, and
take a look at posts...
WinDbg is a great externalutility but it is not integrated with a Visual Studio IDE by default.
Intel Inspector XE, or Microsoft Memory Leaks Detection ( MLD )API of the CRT library, orScaLib MLD APIare able to point
exactly to a source line where a memory was allocated ( because they could beintergated, or already integrated by default,
withVS IDE )and in that case adeveloper doesn't need to "walk the heap" trying to find something suspicious.
On middle- or large-scale software projects developers arealwaysbusy with completely different things related to
implementation of somenew functionality, or stabilization of some codes, etc.
Here is a short example:
* Memory Block: 0 *
..\common\prttests.cpp(6527) [SergeyK]It reports to a line where a new C++ operator was used
* Memory Block: 1 *
..\common\prttests.cpp(6534) [SergeyK]It reports to a line where a new C++ operator was used
Sergey
Bernard
Windbg will be integrated with the next release of Visual Studio.
Sergey I was talking from the "debugging" point of view:)
Btw I have used extensively windbg and I must say that this tool is outstanding and very versatile.
Who is responsible for software - OS interaction debugging when something goes wrongand who do it atmachine code level ?
SergeyKostrov
Please consider it as a programmer'sjoke:
Quoting iliyapolak
Who is responsible for software...
A manager... Because he/shetells software developers what they should do and what they shouldn't... :)
Sergey
Bernard
@Sergey
Do you have an escalation engineers in your team?
