- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Seem to be a problem with modulefiles-setup.sh script. Loaded compiler and prereq's as well as vtune.
Executing icx-cl -fsycl-help fail to locate ocloc and opencl-aot. Loading intel/oneapi/2025.0/vtune/latest sets up an environment which do not include path to vtune.
The error:
torel@login1:~$ icx-cl -fsycl-help
Intel(R) oneAPI DPC++/C++ Compiler for applications running on Intel(R) 64, Version 2025.0.4 Build 20241205
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
Emitting help information for ocloc
Use triple of 'spir64_gen-unknown-unknown' to enable ahead of time compilation
icx-cl: error: unable to execute command: ocloc
Emitting help information for aoc
Use triple of 'spir64_fpga-unknown-unknown' to enable ahead of time compilation
icx-cl: error: unable to execute command: aoc
Emitting help information for opencl-aot
Use triple of 'spir64_x86_64-unknown-unknown' to enable ahead of time compilation
OVERVIEW: OpenCL ahead-of-time (AOT) compilation tool
USAGE: opencl-aot [options] <input SPIR-V or OpenCL program binary>
OPTIONS:
--verbose - Show verbose logs
</snip>
The modulefiles for vtune seems culprit. The prepend-path destination is and environment is not correct. However there is a file in vtune/2025.0/etc/modulefiles/vtune/2025.0 which probably is the correct one.
torel@login1:~$ module show intel/oneapi/2025.0/vtune/2025.0
/cm/shared/modulefiles/intel/oneapi/2025.0/vtune/2025.0:
module-whatis {Intel(R) VTune(TM) Profiler 2025.0.1}
prepend-path PATH /cm/shared/apps/intel/oneapi/2025.0/vtune/2025.0/etc/modulefiles/bin64
setenv VTUNE_PROFILER_2025_DIR /cm/shared/apps/intel/oneapi/2025.0/vtune/2025.0/etc/modulefiles
setenv VTUNE_PROFILER_DIR /cm/shared/apps/intel/oneapi/2025.0/vtune/2025.0/etc/modulefiles
torel@login1:~$ ll /cm/shared/apps/intel/oneapi/2025.0/vtune/2025.0/etc/modulefiles/bin64
ls: cannot access '/cm/shared/apps/intel/oneapi/2025.0/vtune/2025.0/etc/modulefiles/bin64': No such file or directory
I found binaries icx-cl is complaining about in:
torel@login1:/cm/shared/apps/intel/oneapi/2025.0$ du -a . | grep ocloc
89196 ./vtune/2025.0/bin64/gma/GTPin/Profilers/ocloc/Bin/intel64/libigc.so
2008 ./vtune/2025.0/bin64/gma/GTPin/Profilers/ocloc/Bin/intel64/libigdfcl.so
1460 ./vtune/2025.0/bin64/gma/GTPin/Profilers/ocloc/Bin/intel64/libocloc.so
139056 ./vtune/2025.0/bin64/gma/GTPin/Profilers/ocloc/Bin/intel64/libopencl-clang.so
8 ./vtune/2025.0/bin64/gma/GTPin/Profilers/ocloc/Bin/intel64/ocloc
231728 ./vtune/2025.0/bin64/gma/GTPin/Profilers/ocloc/Bin/intel64
torel@login1:/cm/shared/apps/intel/oneapi/2025.0$ du -a . | grep opencl-aot
0 ./2025.0/bin/opencl-aot
1136 ./compiler/2025.0/bin/opencl-aot
torel@login1:/cm/shared/apps/intel/oneapi/2025.0$ du -a . | grep aot
Would it seem that nonstandard installations are not handled very well?
Or am I doing something wrong?
Rgds,
Tore
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi Tore, we would like to inform you that we are routing your query to the engineering team for further assistance.
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Thank you!
In previous versions, because the relative location of module files was different from the installation path, I had to modify the module files, as shown below. However, this has been removed in release 2025.0. Now it only are warned with prereqs.
Why? Bug or feature?
<snip>
# Load dependencies
#if { ![ is-loaded tbb ] } { module load tbb }
if { ![ is-loaded intel/oneapi/2023.1/tbb/latest ] } { module load intel/oneapi/2023.1/tbb/latest
#if { ![ is-loaded compiler-rt ] } { module load compiler-rt }
if { ![ is-loaded intel/oneapi/2023.1/compiler-rt/latest ] } { module load intel/oneapi/2023.1/compiler-rt
/latest }
# Load optional dependencies (if lmod else tcl)
# see: https://github.com/TACC/Lmod/issues/505
if { [ info exists ::env(LMOD_VERSION_MAJOR) ] } {
# if { ![ is-loaded oclfpga ] } { module try-add oclfpga }
if { ![ is-loaded intel/oneapi/2023.1/oclfpga/latest ] } { module try-add intel/oneapi/2023.1/oclfpga
/latest }
} else {
# get original name of the modulefiles containing folder
set modulefolderroot "[file dirname "$ModulesCurrentModulefile"]"
set modulefolderroot "[file dirname "$modulefolderroot"]"
# if { ![ is-loaded oclfpga ] && [ file exists $modulefolderroot/oclfpga ] } { module load oclfpga }
if { ![ is-loaded intel/oneapi/2023.1/oclfpga ] && [ file exists $modulefolderroot/oclfpga ] } { modul
e load intel/oneapi/2023.1/oclfpga }
</snip>
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
The module file issue on VTune has been fixed. Did you try 2025.0.1?
