Analyzers
5307 Discussions
Output from Inspector and application together?
erling_andersen
I am using Intel Inspector on Windows and it finds some uninitialized reads in command line application.
Now I would like Inspector to output that together with output of my program just like valgrind i.e.
My program: Bla bla.
My program: Bla2 Bla2.
Inspector: Unitialized read ....
My program: Bla 3 bla3
Is that possible?
Peter_W_Intel
Actually it is "ready" feature to support of displaying code snippet with problem report, add option "-verbose". For example:
 >inspxe-cl -R problem -verbose -r r008ti3
erling_andersen
What if you use the GUI? Can set this option in the GUI.
Peter_W_Intel
There is no extra work (option) to do on GUI, just open result file, click on the problem, then display problematic source.
erling_andersen
I do that. However, it just tells me where it happens in source and not when e.g. which data triggers the situation.
When I can see when the uniniatialized reads happens in the conjunction with output. Then I have a much better idea where and what to look for.  That valgrind does that and it helps me a lot.
erling_andersen
Btw when using the GUI I can see
  inspxe-cl -collect ti3 -knob terminate-on-deadlock=false -knob stack-depth=16 -knob scope=normal -knob remove-duplicates=true -knob use-maximum-resources=false  ...
I have search the HELP but I cannot find find which -knob there are available.
Peter_W_Intel
>...it just tells me where it happens in source and not when e.g. which data triggers the situation.
It's true...if there are some variables (data) in one statement...but usually it happened in array for most invalid accesses, for uninitialized read, there are only limited data to be checked:-)
Just use, "inspxe-cl -knob-list ti3" to know all supported knob's options.
