Analyzers
5285 Discussions
Problems getting logs with vtlxsc or rmtsvr
alain_lo
Hi all,
I tried to use rmtsvr combined with XscVTuneHostDC.exe to get logs for Vtune Analyser (SRDC mode). On thetarget side, when I stop the sampling, I get a segmentation fault errorand on the host side the XscVTuneHostDC freezes.
Ialso tried TLDC mode using vtlxsc on the target. I do the following commands :
-vtlxsc activity myactivity
- vtlxsc start
Bu then nothing happens. Log files are generated but I can not convert them into tb5.
I get the following error message :
BuildTbxXSC successful... modules added to sample file
Sample file contains 0 samples 778 modules
Unknown CPU - unable to convert to TB5 format for analysis. Convert5 failed.
Did I miss something ?
Alain.
