Analyzers
Profile Failed
YuGang_T_
Hello,I profiled the sample project tachyon vc10, and got a problem.. B elow is the log:
Analyzing Debug configuration
    11/24/14 19:49:16  Profiling Debug configuration may provide misleading results. Change active configuration for performance measurements to Release to accurately reflect the behavior of your released product.
Collection failed
    11/24/14 19:49:23  Collection failed. The data cannot be displayed.
    [Instrumentation Engine]: SYSCALL_INSPECTOR: Too long trace in the NTDLL!NtSetContextThread function Incompatible operating system or incompatible software installed on the system Pin is exiting due to fatal error
My environment is:
intel-i3
WIN 7 64bit
Microsoft VS 2013
NO anti-virus program is running
Thanks in advance, any advise would be appreciated.
Bernard
Valued Contributor I
@YuGang
It seems that there is no installed any hooks or inline trampoline jumps.
YuGang_T_
My VTune Version is, Intel VTune Amplifier XE 2015 (update1_setup).
Peter_W_Intel
Please reference to this thread with similar problem.
YuGang_T_
Thanks for reply.
I Followed his solution and removed all the anti-virus SW. without effect.
Peter_W_Intel
Possibly there was other 3rd-party software - which had installed ntdll.dll patch. If you are not sure what software is - you can try other machine.
Bernard
@YuGang
You can use Windows debugger (windbg)  !chkimg command in order to check for image consistency. In your case I would try to check Ntdll.dll image first for installed hooks.
http://community.websense.com/blogs/securitylabs/archive/2010/04/29/analyzing-malwares-using-microsoft-tools.aspx
YuGang_T_
iliyapolak wrote:
@YuGang
http://community.websense.com/blogs/securitylabs/archive/2010/04/29/anal...
Thanks for reply.
I've got the windbg tool and then how should i use it to trace the problem.
I read the article above but still dont know how to !chkimg, for i dont have a dump file.
Bernard
@YuGang
Please download following tool for creating user mode dump file : http://www.microsoft.com/en-us/download/details.aspx?id=4060
Proceed further as it was explained in this article http://community.websense.com/blogs/securitylabs/archive/2010/04/29/analyzing-malwares-using-microsoft-tools.aspx
If you want you can send me dump files and I will run !chkimg command.
YuGang_T_
iliyapolak wrote:
@YuGang
Proceed further as it was explained in this article http://community.websense.com/blogs/securitylabs/archive/2010/04/29/anal...
Windbg can not show the command window any more on my pc.
I upload 2 dump files, will u please !chkimg them. Thanks.
Bernard
@YuGang
Tomorrow I will check those files.
YuGang_T_
Thank you
Bernard
You are welcome.
Bernard
@YuGang
YuGang_T_
iliyapolak wrote:
@YuGang
Seems my windows system need to be reinstalled.
Bernard
@YuGang
Probably it can be the best solution in your case. I will run !chkimg on my other laptop in order to verify the results.
